Laying out flutes on a bowl or vessel
Steven Potts
>Can anyone help me find some info on laying out patterns on vessels, I'm not a math wiz, so please help
Steven Potts
Re: Laying out flutes on a bowl or vessel
tm
>Have a look at a book titled Masterful Woodturning by S. Gary Roberts
I got mine on sale at Rockler.
Lots of projects & ideas for the skilled turner.
I dont think I'm on that level yet but it shows how to do some impressive pieces.
tm
>I'm terrible at math. I use masking tape. Wrap the tape around the area you want to divide. Put a mark where the tape overlaps so you have a beginning and end. Then take off the masking tape and tape it to your workbench. Now simply divide it into any number of segments. I use dividers and just step it off but you could take a ruler, measure the total distance and divide it.
If you need curved flutes use the same method with tape at the top and bottom. To offset them the right way use a flexible piece of metal or plastic to draw the first line. I use either a hacksaw blade or piece of Formica. Put the first piece of tape on and align the metal with the first mark. Then adjust the other end of the metal until it has the angle you want. Now put the second piece of tape that you marked off on the other end. Then you simply align the metal with the marks on both ends and draw a line.
Re: I generally use the indexing ......
Jamie Donaldson
>.....set-up on the lathe and a strip of thin aluminum, which can be easily shaped to fit the form profile. Pencil in the lines and start carving.
Re: Laying out flutes on a bowl or vessel *LINK*
Leppikallio
>I followed link posted recently and there was some interesting pictures, for example pictures from Al Stirt demo, perfect and easy solution for dividing etc.
http://www.cicaaw.org/image/tid/91
eliot d
>Incidentally, suppose you want to divide your piece of tape, which is less than 12 inch long, into, say, 12 equal segments. Then, without any math, put down the tape in a horizontal position. Then mark twelve one inch segments on another strip of some kind -- just by using a ruler -- and slant it relative to your tape so that the two end points of the slanted strip line up with the end points of your horizontal tape along two vertical lines. Then just drop down the other verticals from the slanted line to you tape, and the divisions on you tape will be exactly right. You can clearly extend this method to any length of tape. The point is that the tape may be (and probably will be) some odd- ball length, but you can fix up the longer slanted line any way you want to make the divisions simple on it. No math!
