Using Wax
Tomm
>I keep reading about using wax or oil on torn grain before shear scraping. Will the past wax or oil interfere with a water-based finish or is it all removed with the shear scrape and sanding? Thanks for your comments.
Using Wax
Tomm
Re: Using Wax
tek-Brunswick, Ohio
>Oil or Wax will interfere with a water-based finish. Usually an Oil based finish would be used after that technique. You could use a coat of dewaxed shellac as a sealer and then use water based finish over that.
Re: Using Wax
Ron in Drums PA
>I always thought so.
I use either oil, shellac and sometimes water.
Re: Using Wax
Devon Palmer
>I had pieces previously finished with walnut oil and didn't care for at ALL. I sealed with Shellac (Zinzer, dewaxed, yellow can) and put water poly over it with no problems so far.
Shellac under water poly is now my favorite finish as the shellac makes the grain really pop, and the water based poly is REALLY durable. Without the shellac, the water based finish just looks "dead" on top of the wood IMHO.
- Devo
Re: Using Wax
>Tomm Your right. I use lacquer sanding sealer instead of wax, since I usually use lacquer as my finish. On boxes I use wax on the enterior so I can use wax there to solve tearout problems.
