segmented vessel
segmented vessel
segmented vessel
Adam (cincinnati OH)
>Im contemplating on how to make a segmented vessel without the aid of a lathe. Could bending the wood to a desired shape be a possible alternative? I was thinking about making something cylindrical, so there would be no vertical curve.
Re: segmented vessel
Mike Hamilton
>I saw some hollow forms J. R. Beall did by making a set of molds. He would glue up three plys of veneer and press it in the molds. He planed/sanded the edges of the glue up back to the edges of the molds and ended up with a section that was a sixth of a circle. Three ply thickness was enough that he could edge glue six of the pieces to complete the form. I think one of these pieces is frequently seen in the background of his promo literature.
Regards,
Mike Hamilton
Plainfield, IN
>Adam You can get bendable plywood that will let you bend the wood into a curve. Depends on how tight the radius will be and how thick you want the walls.
Look at Shaker boxes and you will see how to bend green wood into an oval. You should be able to bend it into a cylinder using the same method. for larger radius with thin walls look at guitar building.
The other way people do bowls without a lathe is to use the bandsaw to cut half rings and then glue these togehter into rings and stack them up to make a vessel. You can do the same thing with a scroll saw but you make whole rings instead of half rings. You can tilt the table on these to make the rings taper so they will stack.
Mark Kauder
>You can always make a number of segmented rings, all the same diameter, sand the tops and bottoms flat, and glue the stack up. Once dry you can Sand, Plane, carve, Bandsaw, or whatever the piece round.
Mark
