Speaking of hollow forms.....
Leslie S
>Does the grain orientation matter when making a holow form? In other words, should the top and bottom be endgrain or like bowls with end grain on the sides.
Leslie S
Re: Speaking of hollow forms.....
Carole Valentine
>I've do them both ways depending on the look I want. Never thought about if there was a right way or a wrong way come to think of it! LOL
Mike Cunningham (Cape May NJ)
>You'll be hollowing end grain or long/side grain depending on orientation which will require a different approach. Drying will also effect movement differently end grain vs long/side grain.
My taller forms are end grain, my shorter/wider are bowl orientation. But I've done them both ways.
Wally is probably the best person to answer this.
Mike
Either: Depends...
Brad Vietje
>You can make 'em either way. It all depends on what look you want, and how you will be featuring the figure of the wood.
I find that endgrain orientation is a shade easier because there usually isn't the alteration from endgrain to sidegrain, which happens twice per revolution. this can cut down on vibration and chatter, especially when you are reaching far over the rest, or making something a little large for the tools at (in) hand. I also find I get small chips in endgrain HF's which are easier to remove, versus longer shavings in sidegrain HF's that can be more difficult to remove,
Endgrain rough-outs tend to move a lot less as they dry, so you can get closer to final thickness in rough turning (thinner walls--> faster drying and usually fewer cracks). Cleanest cut on endgrain hollow forms is from center toward outer wall; opposite when turning sidegrain.
Have fun,
Brad Vietje
Newbury, VT
Devon Palmer
>Not that I'm that experienced... but,
I prefer to do them with spindle/side grain orientation - The outside shaping cuts can be made downhill with ease, the strength runs along the piece, and it warps evenly given the symmetrical orientation of the grain throughout the piece.
- Devo
Mike Hunter
>Lets minimize the sanding. For hollowing, lets cut fine shavings on our finish cuts. Check out Hunter Tool Systems under the marketplace.
Leslie S
>Thanks folks, hometeam won the hockey game and I have a Bill Grumbine demo to take in over the weekend. Now if it would only stop raining and SNOW! ;)
