A question that I thought I would never ask
Ron in Drums PA
>My daughters and I are doing a collaboration Xmas gift for their mother. I'm turning two pieces from holly and they are going to paint on to the form. I plan on using a lacquer finish.
My question is...
Do I apply the lacquer first then have my girls do the painting?
or
Do my girls paint first, then I apply the lacquer second?
TIA
Re: A question that I thought I would never ask
Mike Cunningham (Cape May NJ)
>My resident surface embellisher and wife says that she paints with acrylic then applies the lacquer. We've done a number of holly boxes the past few years and that's her course of action. She also advises that on some porous woods, she first applies a sealer, then pain, then finish.
Ron in Drums PA
>Thanks Mike.
BTW, there is a surprise headed your way. You should see it on Thursday.
Mark Kauder
>Ron,
I basically agree with Mike. You can do it either way, but it depends on your desired outcome. An application of lacquer first will seal the wood well, so that the other paint will not bleed across the wood. If you want the crafty look, having no finish over the paint, allows the texture of the paint to show. Sometimes a lacquer over the paint will give it too much of a production look.
If it were me, and this is what I used to do when my wife decorated bowls - 1) a thinned 50/50 lacquer applied and then wiped off almost immedately, then applied again and wiped off (just as a sealer), 2) then the Painting, and then 3) The finish application. Test the finish application of lacquer over the same wood with the same paint. Lacquer thinners are strong, and can wrinkle some paints, and to wet an application can make some runn.
Good luck,
Mark
>Man I love surprises!....Especially from woodturning friends!
Thanks,
Mike
Thanks Mark
Ron in Drums PA
