THE WOODRAT IS BACK!
cleaning face mask shield
eliot d
>I just replaced a shield on on a face mask. It wasn't expensive, and it was simple. But I was wondering whether or not there's a way to buff out the scratches on a used one in a pinch.
Re: cleaning face mask shield
Al Crandall (NE of Indy)
>Many many years ago I heard of a product called micro mesh which was designed to buff out scratches from aircraft windshields. Since the woodturning community has discovered it, I supposed it could still be use for plastic polishing.
dwr
>Micro Mesh works great. I actually rubbed out scratches in my daughters car mirror with it... only took about a minute.
bowlman
>You can also use Novus Plastic Polishes. Heavy scratches need number 3 followed by number 2. For generally cleaning and minor scratches try number 2 followed by number 1. USe number 1 on a weekly basis and you'll be able to rescue face shields that you normally would replace.
RPE
>Or, you can go to Staples and purchase some clear document protectors. They are a very cheap. Cut a pattern of your face mask out of paper and then place it on the document protectors. Cut it out with siccors. Use two small pieces of masking tape to hold in place. When you get glue, wax or finish all over it. Remove it and throw it away and cut out a new one.
There are many kinds of document protectors, make sure you purchase the clear ones, not the cloudy kind.
Much cheaper than mico mesh and quicker than buffing it out.
Re: Armor All will clean most of the.....
Jamie Donaldson
>....gunk and fill the scratches, and also reduce the tendancy to hold a static charge which acts as a dust attractor.
Scott Hurley in N. VA
>I recently tried my Beal Buff system (also suggested here on Woodcentral) on my face shield - worked very well. The tripoli did a great job of getting out minor scratches, and the white diamond polished it up nicely. I took it out of the holder and held it flat while I moved it over the wheel - that way you can do both sides, if needed.
Scott
