Loud belt noise
Loud belt noise
Loud belt noise
eliot d
>I have a Powermatic 2530A lathe. When I crank up the speed a bit, there's a fair amount of sound generated from the belt/pulley system. It sounds something like a loud fan. Is this normal? I notice at our club that the Stubby doesn't seem to make any noise to speak of.
Re: Loud belt noise
Re: Loud belt noise
>Are you sure it's the belt. The fan on the motor does make a lot of noise. Just to be on the safe side check and see if the pulleys are aligned. If thier off I suppose you would hear some noise, not sure it would sound like a fan. The stubby is one of the quietest machines I've ever been around so you really can't compare the two.
Re: Loud belt noise
Re: Loud belt noise
eliot d
>I checked the pulley/belt alignment and moved it a tiny bit. but that didn't seem to matter much. But tightening the belt did the trick! It's much quieter now. More importantly, I thought I was loosing my grip because a vessel I was turning on the outside (fairly large diameter of about 10 inches) just wouldn't stop chattering against the tool. No matter what I did the tool kept knocking against the wood ; I just couldn't get a smooth cut. I thought it might be my expensive Vicmark chuck; then I started to doubt the lathe .I was going crazy! Finally,tightening the belt, which stopped most of the noise did the trick. I think the belt may have been slipping; so at a micro level, it was grabbing and letting go at a high rate of speed, which somehow or another caused vibration in the transverse direction. Any thoughts?
