A55 Smoothing Plane
Sharpening question
Sharpening question
Sharpening question
Mike Cunningham (Cape May NJ)
>A member of my club has a question, perhaps someone here as an answer.
He has Delta Sharpening Center with a white 200 grit vertical high speed stone and a wet 800 grit horizontal slow speed wheel.
He wonders if a commercially made jig for sharpening gouges is available or if one can be adapted for use with the wet horizontal wheel. Or, has anyone built such a jig and would share the info.
I'm a Tormek guy and while I've seen the Delta set up, have no knowledge of it's functionality, etc.
Thanks in advance!
Mike
Re: Sharpening question
Hooligan
>I've seen an adapter for the Delta Station that allows the use of the tormek jigs. I can't remember WHERE I saw it, but know that it is out there and available.
>Mike I would not use the horizontal stone to sharpen any lathe tools other than the skew. You will groove the stone and make it hard to use for sharpening other tools like chisels and plane blades. Iwent that route with a Makita horizontal stone.
I prefer 60 or 80 grit for my lathe tools but will go as high as 100 on occasion. To sharpen successfully on a 200 or 800 grit stone you would need an accurate jig unless your really good at hand sharpening.
Mike Nelson
>I have the same unit and used to try to sharpen on the top wet wheel, all I have now is a bunch of dips and valleys. It usually just messes up the edge I put on with the white stone. By the way I have worn the white stone down quite a bit and when trying to true it up its always just a little out of round, any ideas?
Thanks guys!
