We value your privacy.
>Hello: I was looking at some of my reading material and it talks about a chatter tool. Anyone have any advice on how to make one? I looked in one of my catalogs and there was one listed but seemed kind of expensive. It seems like I should be able to make one with a little help from my friends here. Thanks in advance Jared
>Take a piece of 3/8 to 1/2 inch diameter pipe about a foot long and drill and tap a hole for a set screw about 1/2 inch from one end. Grind the teeth off of an old high speed steel jig saw blade and sharpen the end to a pointed "V". Insert the blade into the pipe and secure with the set screw. The chatter pattern varies based on lathe speed, length blade is protruding, hardness of wood, end grain vs side grain,speed and direction you sweep your chatter tool, heighth of tool rest, etc. Experiment!
>Also take a look in the Articles link in the maroon panel on the left and click on Turning Tools and techniques. Next scroll down to the article by John Lucas.
>All it takes is a piece of spring steel and a pair of vice grips. I demo with a short piece of industrial hacksaw blade. I ground the teeth off. The way a chatter tool works is the vibration of the cutting tool which is the spring. The shorter it is the faster it vibrates and of course longer ones vibrate slower. Each one creates a different pattern. The tip is ground like a scraper either round nose or v shaped. You'll probably find the round nose works better to start.
Put the pliers on the tool rest with the spring steel extended out over the tool rest. push the end into the work and let it vibrate. It only works on endgrain and at first is very unpredictable. Take a scrap piece of hard wood and mount it in your chuck so the end grain is out. I use a 2" cylinder. Then try your hand at chattering. clean this off with a spindle gouge and try again. You'll get the hang of it after awhile. I make little chatter work buttons this way and I can insert them into other projects.
>I have a Craftsman hacksaw blade holder that works pretty good. The kind without a frame, just a handle. Or check out my plans for making a sturdy chattertool handle using a lagscrew, a small pipe nipple and a setscrew:
>I waiting for my shop to warm up so I did a quick chatter tool demo with the vice grips and a used blade from an industrial cutoff saw. They throw these away at any building site where they are installing metal studs. You can get them by the hundreds (I've told you a million times not to exagerate so much).
I ground the tip to a V groove. sometimes the grinder won't put the burr on the top like it does with turning scrapers. If that happens just flip the tool so the burr is up.
>here is the tool in use. put the blade about 8 oclock on the wood and tilted to the left or right. you can pull the blade in either direction. It produces different patterns based on which way you angle it, which way you pull it, how fast the lathe is moving and how far from center your cutting, how much of the blade prodrudes from the pliers and how thick the blade is. Needless to say with this many variable it takes a lot of use to get even remotely predicatable results. That's why I tend to turn buttons out of wood that chatters well and insert them in other projects rather than risking ruining the good project. It's not really that risky after you get the hang of it.
Sorry for the photo quality, I got motion blur since I was using tungsten lights. I thought that might be a problem but took the shot anyway. It was getting cold out there.
>here are the results of one pass. You do need to get a reallly clean cut and or sand the end grain before you do the chatter work. You can't sand afterword. Well actually you can but you better start with 400 or higher and only just touch it. I often rub it while it spins with a soft piece of wood. This knocks off some of the fuzz but doesn't damage the chatter work.
this is a sublte kind of chatter work. For larger and deeper chatter work make the blade longer and stiffer. Sometimes on these blades you can just put 2 blades in there but only use one blade for the actual cutting.
>Here are some leftover chatter buttons from previous demos and projects. The green ones are Corian, the white ones are Tagua nut, and the other was cocobolo. Tagua chatters great because it's hard and doesn't have any grain but the chatterwork is usually small. My favorite is the gold button on the back. Sorry you can't see the details as well. I color them gold with a marker after the chatter work is done. Felt tip markers are really great for this.
If you look at the cocobolo button, I ran the chatter tool from R to L on one run and L to R on the next run. This produces lines the tilt in the opposite direction. Then I clean up the juncture and outer edges with a spindle gouge to leave it looking nice.
>Ron I'm going to try to write it up later today and submit it to the tips pages. I've got to make a lot of headway on the carved bowl I'm working on today. The weather is going to be good enought to use the chainsaw on it to rough it out. Then I'll be known as a chainsaw artist, and can start carving my giant Indian. :)
