Re: Bleaching wood
>I use the "A/B" mix bleach (Kleen-Strip or other brands). You must sand off any finish, and it's well to degrease and rinse the piece if there's any oil on it. A final light sanding with the highest grit you intend to use should be done, and then the piece vacuumed off.
You mix only enough of the 2 parts for the job and apply to evenly soak the surface. After an hour or so, you can apply just part B if necessary. You then wait 2-3 hours and either reapply with more mixed solution or neutralize the now highly caustic wood with dilute white vinegar. Dispose of any unused mixed solution with care.
It will tend to raise the grain so you will need to lightly resand the surface before finishing. You must be careful or you'll sand through the bleached layer.
You will need good rubber gloves and care in handling, including the wood before it's neutralized.
