Lee Valley Grinding wheels
Carole Valentine
>Anyone used them? Comments, good or bad? Picture looks like they are made by Norton but I am sure they are not a 3X equivalent at that price.
Carole Valentine
Re: Lee Valley Grinding wheels
Jim Shaver Oakville, Ont.
>Hi Carole,
I use the LV wheels, I do believe they are Nortons. I have a 80 and a 120 on my slow rpm 8" grinder. I use the 80 mostly, not only for turning but also my plane irons and chiels...they work great.
I installed the Oneway balancers about three years ago, that was a big improvement as well.
I am still on my first wheel, I have had it 7 years.
Take care,
Jim
Carol from AZ
>Would the 80 grit be the choice for a high speed grinder as well? For sharpening turning tools.
Russ Babbitt
>The wheels you are looking at from Lee Valley are aluminum oxide. The 3X's are ceramic.
Re: Lee Valley Grinding wheels *LINK*
Bob Fawcett
>I used a 120 on my high speed grinder. It worked well, but wears faster than a 3x or SG wears. For the price they are tough to beat. The wheel parameters were selected to use for tool sharpening and are a close match to the ones Bill Tindal recommends in this article.
Grinding Wheels
Ed in Leaside (Toronto, Ontario)
>Yes, they are Norton wheels. There was a thread on the hand tool board which may be of interest to you.
Hooligan
>They are just "ok", in my experience. I have had much better luck with Oneway, and genuine branded Norton wheels. I tried the Lee Valley, and another that are made by Norton, and they don't seem to perform as well as the Norton.
My choice of wheel now, is actually the 8" Oneway 80 Grit at 3450 RPM. Better finish, and less glazing, less dressing.
Carole Valentine
>Carol,
Personally, I use 80 grit for gouges, scrapers, etc and 120 for skews and parting tools. Your mileage may vary...
Keith Tompkins
>HI Carol, 80 grit on the HS grinder is ok. It will leave a finer finish than with a low speed grinder. The secret to using the HS grinder is LIGHT pressure...sometimes just the weight of the tool will do it.
Carol from AZ
>Thanks, Keith. Duly noted. My file for Bill grows thanks to all of you.
Thanks everyone!
Carole Valentine
Darrell Feltmate
>Carole
I am odd man out here. I like the Lee Valley wheels but they and other white wheels are too soft for my liking. I use jigs and a light touch but even so I like a regular bond aluminum oxide wheel, 80 grit, on a high speed grinder. If I am going to get a lot of flack on this, someone open another thread so Carole's does not get too confusing.
Around the Woods
