Laser Boom Question
Laser Boom Question
Laser Boom Question
>I'd like to hear from those who are using laser "guided" hollowers.
Have any of you tried/used a counter-weight at the opposite end of the laser holder boom to balance the weight and reduce vibration at the working end? If so, to what effect, and how much weight is/was used?
My boom is 1/2" EMT (5/8 id) that has been filled with 1-part urethane foam.
TIA
MM
Re: Laser Boom Question
>Mark I built the one in American woodturner about a 2 years ago. I would have to look. It's made from square tubing. Someone else suggested in a tip to fill the tubing with that spray foam insulation to reduce vibration. I did, and it did. I didn't have bad vibration problems with this setup anyway but it did reduce them.
Dick Hines
Dick Hines
>I don't have any viberation with my Kelton. Solid as a rock.
Re: Laser
>Stays smooth for the outside finish cuts, but dances on the interior hollowing. Perhaps I'm expecting too much. Right now, I'm using an el Cheapo laser level until the laser pointers on-order get here. They promise to be quite a bit lighter, so that may solve the bouncy "problem", but still wanted some feedback from others.
I built Al Crandal's rig for my Jet mini
Don Henthorn
>and I have had no vibration problems with the laser.
Re: Laser
Ed in Leaside (Toronto, Ontario)
>Don't know if this is any help, but I was looking to make a laser based Morse taper headstock alignment gizmo. All the laser pointers at the local Staples had points that were too large so I passed. Later, I was at the HD for something else and saw some $15 levels marked down to $5. This is what I found inside (after hacksawing it apart). Exactly what I was looking for. ;)
Ed
Re: I built Al Crandal's rig for my Jet mini
eliot d
>I have three hollowing systems with lasers: the Spin Doctor, the Elbo, and the Don Derry. None of them vibrate. Without question the best laser mechanism is the Don Derry -- not necessarily the best rig, but the best laser by far. You can buy just the laser mechanism for $100. the last time I looked. It is an X-axis/Y-axis arrangement with zero lash-back threads so there is absolutely no movement once you set the laser light where you want it. (I have no affiliation with
Don Derry.) A friend of mine combined Derry's laser with the Elbo , and I think it's just about perfect for small to medium sized vessels. For large jobs I find the Spin Doctor to be the way to go.
