Craftsman Elec Saw - Worked great for about 10 min
Gary Ratajczak
>Hello all!
Looking for a few tips. I bought a 16" Craftsman electric chainsaw a short time back, and finally got a chance to try. Just doing small turnings for now, and no budget yet for a Stihl.
I built a small saw buck to hold my maple logs, and chunked up two 10" diameter x 18" logs. All was well.
I proceeded to halve the logs (with the grain cut), and made it through two chunks. One the next cut - no go - the gear was stripped. Chain would not turn.
After looking things over, it looks like the long shavings made when you do a with the grain cut just don't eject well. Looks like the back side blade cover prevents them from coming out well, jams the chain, and caused me to strip the gear.
So - still under warranty (purchased extended also). I'm covered, but was wondering if anybody has run into this.
Seems to me that the guard needs some material removed at the bottom to allow better exit of the long shavings.
Thoughts?
Re: Craftsman Elec Saw - Worked great for about 10 min
Re: Craftsman Elec Saw - Worked great for about 10 *LINK*
Mike DeLong
>Check out Andi Wolfe's blog for how Lyle Jamieson handled the problem with his Craftsman electric chain saw. I couldn't link directly to the picture so you will have to scroll down about half-way:
Mike
Andi Wolfe's Blog for September
Carole Valentine
>Hi Gary,
I am certainly not a chainsaw expert, but that type of cut will clog my Stihl because it produces long shavings instead of chips like you get with a crosscut. Try cutting at more of an angle (with the nose of the saw lower than the handle). This produces shorter shavings that are less likely to clog. I think some have modified their covers to allow the "ribbons" to eject easier, but I didn't want to do that.
THANKS!!!!
Gary Ratajczak
>Wow - That was quick!!!!!
Carole - Thanks for the technique - I'm new to chainsaws
Mike - Awesome - just what I had in mind!!
Thanks again Ellis for Woodcenttral!!!!!
Re: THANKS!!!!
David Breth
>Ditto! I experience the exact same problem with the exact same chainsaw. Right down to blowing out the first chainsaw under warranty. Looks like I'll be making the exact same modification.
David B.
AndiWolfe
>The exact post is:
http://andiwolfe.blogspot.com/2006/09/visit-with-lyle-jamieson.html
>I agree with Carol. When I rip with my Sears chain saw, I tip the handle down and cut with the nose elevated at about forty five degrees. I still cut for a minute and clean and cut for a minute and clean the chute, but it works better. I have tried cutting perpendicular to the end grain and it produces powder, but is a very tough cut. I also use very little oil in mine, it doesn't pump, it just leaks it onto the bar and it makes a mess if you set it down full of oil. Mine is "sap" lubricated.
I killed a Lowes (Remington) and bought a similar one from Sears with the extended warranty. Wouldn't you know? It won't die. I thought by now I would have had two or three.
Brad Vietje
Consider a ripping chain
Brad Vietje
>There are different chains for ripping, with cutting teeth sharpened straight across instead of the usual angle found on cross-sut chains. They probably have different rakers, and/or other differences too, but I'm not certain about that. If you do a lot of ripping, or mill lumber or turning blanks often, you might want to get a second chain that you put on for those rip-cut sessions. Changing blades can be a pain on some models, but is pretty quick and easy on most.
BTW, almost any saw, electric or gas, will clog up occasionally from the longer shavings we get when cutting "long grain" (side grain cut parallel to the long axis of the tree). Like most, I try to angle the cuts, but still have to stop and clear shavings at times. (Stihl E20)
Safe spinning,
Brad Vietje
Newbury, VT
Re: Missing important piece of information,.....
Jamie Donaldson
>...was the gear metal or plastic like the ones I killed years ago? The saws with plastic drive gears are on borrowed time when new! It really helps to make rip cuts with the bar angled slightly up,handle down, thus eliminating the long shavings that will choke any saw.
Gary Ratajczak
>Given the warranty and free replacement, I'll let Sears worry about what's in there. I assume a plastic gear. Thanks all for the tip on angled cut - I would not have picked up on that.
Going shopping with the wife this weekend, and will stop by Sears to get my replacement. I'll be giving it another try!!
Barry L Elder
>If you are ever in Fort Pierce, Fl I will provide you with a Sears Electric Chainsaw that is sitting in storage. Swap for a chunk of turning wood.
