Veritas - Innovation in Tools
Hard Maple
Hard Maple
Hard Maple
David Breth
>I thought it was time I shared something - haven't posted photos in ages. Most of you turned bowl #35 a long, long time ago, I turned mine a few weeks ago. This hard maple was part of a find at a local wood-dump area. I knew it would split when I was turning it, but I was curious how much, and whether or not I could preserve the turning.
It turned well enough on the bottom, but when I flipped it and started hogging out material from the inside, the split started to give way. Necessity mothered some invention. I used plastic tie-wraps (zip strips) around the exterior of the bowl to keep it from blowing apart, and then removed material from thh inside. I was pretty careful, because the whole operation was pretty delicate. I like the results a lot. This is my current favorite bowl (of mine).
I think of it as a "two-faced" bowl. On one side of the split, where the bugs got after it, is very dead looking. The other side of the split is really vibrant, at least I think so. My terminology isn't great, but I think there is some feathering in there. Photos aren't terrific, but I think you'll get the idea from them. Finish is Minwax Antique Oil Finish, not sure how many coats. A few.
David B.
Re: Hard Maple
Re: Hard Maple
David Breth
Re: Hard Maple
Re: Hard Maple
David Breth
Re: Hard Maple
Great Bowl!......
Blake Washburn
>Where did you get the idea for the shape from? It's very unique. Did you CA glue the crack any to give it support?
Blake Washburn
Re: Hard Maple
Re: Great Bowl!......
David Breth
>Thanks very much - I notice you posted something a moment ago yourself, and I haven't had a chance to look yet.
I have no idea where the idea for the shape came from. The grooves just kind of looked like they needed to be there. Didn't use any ca on it. What happened was, as I turned the inside, I realized that the more material I removed, the more the "halves" would separate, so I allowed that to happen a little bit, then added the zip strip, then stopped removing material from the bottom a little earlier than usual. The bottom is a bit thicker than the walls for that reason. The moment of truth was when the zip-strips came off and I still had something that was in tact. It moved around a bit for a couple of days afterward, but seems to be stable now.
David B.
