We value your privacy.
Has anyone checked out the new mini lathe from Rockler? I dont turn much but would like to and it seems like its comparable to the JET but at a better price.
Bed extension is only $50. And if nothing else get the variable speed motor kit at Penn State for $110 and you have a VS for less than a Jet multi speed...
I will give feedback Saturday after 6-8 hours run time.
I'll be interested to see how you rate this lathe, especially as an experienced (and very talented!) turner comparing its fit, finish and overall quality to standards established by well-known lathe models.
This looks like a great price; it's only a great value if it is rugged and well made. In general, lower priced knock-off's tend to have plastic handles, lower quality bearings, and not-so-precise machining. In my experience, the makers of "entry-level" machines don't design their products for very heavy or precise work, so we probably won't find a true gem at a great price very often.
I think the machining is usually the place where discount lathes fall down. In particular, spindle runout, and how well the top and bottom of the bed are flattened and parallel, and whether the toolrest banjo slides and locks uniformly over the entire bed. What is the lock mechanism of the banjo and tailstock ? Any shortcuts in machining the headstock can result in mis-alignment of centers at either end. Another weakness of many small lathes is found inside the tailstock: when advancing the tailstock ram, just what are we pushing against ?
In my older 1236, there is an "E" ring sitting in a machined groove, and that pushes against the rear end of the cast iron casting. Over about 4 years, I managed to wear (drill?) right through the tail end of the tailstock with that E-ring, and a new tailstock casting was needed. Some of these poor designs are hard to detect, and only make themselves known a few years down the road, when all warranties are long expired. This isn't so much a machining or quality control issue, just a real bad design that certainly saved the manufacturer a few bucks, who might have figured very few people would ever work the machine hard enough to have a problem. BTW, WMH Tool Group sent me new tailstock casting for free -- good folks.
After 4 hours the motor was little warm. So we turned on the other Jets just to let it cool down.
It was fresh out of the box. So might be fine now that it has been running for awhile. Bearings ran smooth and cool.
Rockler said they are backing it with a 2 year warranty, and have parts in the warehouse.
So if you dont have to have the electronic variable speed, it is hard to beat this one for the price. I would like to see how it does in the bowl class.
