We value your privacy.
>I know what it is. Both wheels of the bandsaw running in the same plane. I guess my question is, how to achieve this. Blade one, blade off? Adjusted to track and under tension? I have the set of shim washers form Iturra, but I can't get my head wrapped around the approach to making it happen. Is the goal to get the blade tracking correctly and the wheels coplanor at that moment?
>Takes a little fiddling but the way I do it is to put a 4 foot ruler on the wheels so it touches the top and bottom of both wheels. sometimes you have to shim the bottom wheel and of course you adjust the top wheel until it touches the ruler. Then I put the blade on and check for tracking and readjust the top wheel if necessary. If you have good tires that are crowned properly you shouldn't have to readjust the tracking after making the wheels coplaner.
The only way I've found to check if they are spinning in the same plane (such as when you put an aftermarket riser block on a machine) is to clamp a straight edge on the top and and another identical one on the bottom wheel so they are parallel to the floor and then drop a plumb bob down. Of course the machine must be perfectly level before you do this or it won't tell you much.
>I have had the same question for years and no one seems to understand the question enough to give an (or 'the') answer I am looking for. What I finally ended up doing, and it seems to have worked so far, is to use a wider (3/8" or 1/2") blade and at correct tension, get it to track as best I could (in my case, centered on top wheel and toward the front on the bottom), running under power. I did the level spanning the two wheels bit and shimmed accordingly.
>What would I level? Seems to me I am going round and round. Do I square the table to the blade and then check see if it is level? And yes, I do have a riser block in it.
>Could you tell us the make and model of saw? There is at least one that has some issues with the riser block pins not lining up right and it is darn near impossible to get it co planner. I used a piece of oak that I ran through the jointer to be sure it was straight. When it has contact across both wheels they are in the same plane. I had to removed the tabe to do that but later thought that I could have tilted it enough to get it to work. I don't know what leveling has to do with anything? Maybe I just didn't understand what I was doing.....
>Barry I checked my floor for level (which it wasn't exactly) so I checked the table front to back not left to right in the direction it tilts. Anyway I shimmed the base of the saw until the table set level. Then I checked the wheels by clamping 2 straight boards to the wheels and dropped a plumb down to see if both wheels were aligned with each other. This would tell you if the axles were aligned in the left and right planes. You could also drop a plumb from the top wheel to the bottom wheel without a straight edge and see if it touches the wheels top and bottom.
>and cut it down. I think I would mount the tire on a wheel and try to cut it while it is turning. You would surely need a rest for the cutter and do careful work.
Its been a year or more since I tried the coplanar thing. As I recall, I put washers/shims in until the wheels were coplanar without a blade, but when I put the blade on and tensioned it and got it to track, it was no longer coplanar.
If the idea here is that you should be able to get the wheels coplanar without and blade and ten put on a blade and tension it and it would track without adjusting the wheels, I don't think that is going to happen for me. Maybe if the tires were perfect and the blade was perfect.
I used a level as a straight edge and shimmed them until they were coplanar in the center, near each axle, then checked them near the front and rear of each wheel. It seems to me that if they were truly coplanar, then a strait edge would touch the rims of both wheels, front and rear, near the center and even diagonally.
>I don't understand that either, Barry so I quit worrying about it. It never made sense to me to get the wheels in the same plane if I just had to adjust the top one out of that plane to get a new blade to track properly. If you ever figure it all out, may you can splain it to me in plain English. Meanwhile, I'll just continue on as is with my bandsaw apparently working just fine. ;))
>The top wheel is adjustable and the bottom wheel is stationary, so the bottom wheel determines the control plane. A line drawn from 9 o'clock to 3 o'clock on each wheel should fall into a plane. This lets the blade transition from wheel to wheel without too much warping. If the saw can be set up with the top wheel 9/3 line in the same plane as the entire bottom wheel (measure at 3, 6, and 9o'clock on the bottom wheel), so much the better. If not, just shim the wheels to get as close to this condition as possible. Any measurement involving a line on the wheels from 12 o'clock to 6 o'clock is irrevelavent because this in the adjustment line for tracking.
>Thanks Don, I'm beginning to think you're right. The wheels on this saw have small groves on either side, wonder if that will matter? I doubt it. Anyhow I've actually cut a few blanks with no tire! Stays in the middle, but I don't think it will last much longer.
