Jet 1642 adding a swing lamp
Dennis Taylor
>Seen a picture somewhere, where the cage shield was removed from the head stock and something was mounted to put a swing arm lamp into, does anyone know of a mounting means for the lamp?...I use a overhead light, but need something more direct...tks..Dennis
Re: Jet 1642 adding a swing lamp
Re: You probably saw our club lathe light mount.
Al Crandall (NE of Indy)
>Pictures of Ellis turning on our club lathe during Indy Fest prompted some discussion of the lamp mount. Duane Leach and I combined ideas to come up with that mount in a hurry for an out-of-town demonstrator. It was quick and dirty, but effective. A round tenon, sized to fit the hole in the cage mount, was turned on a portion of a rectangular wood piece. A little hand whittling at the base of the tenon allowed the wood to fit up snugly into the ribs of the cage mount so that it wouldn't torque when the lamp was installed. A small detent was drilled in the side of the tenon so that the stock Jet shot pin would engage it and the assembly couldn't move laterally. Finally, a hole was drilled in the top of the exposed rectangular part to accept the shank of the articulated lamp, and the rest is history. Thanks for asking.
Re: Al, is there any way you can
Allen Neighbors
>post a pic of this rig? I've been debating about a way to mount a light on my lathe, and it might give me some ideas. I know... I don't have the cage mount on mine... but I do have other places that I might mount a light. Just haven't quite figured it out, yet.
Ric Taylor
Ric Taylor
>I never installed the cage shield on my Jet 1642. I'm thinking about throwing it away, it just wastes space on the shelf.
Re: Al, is there any way you can *LINK*
Bob Fawcett
>Allen,
I posted this on the other side since I mounted it on my bench.
"I went to Staples and got a 45" Architect Desk Lamp. Its a 150 watt halogen on a 45" flex arm. It has a clamp that could clamp to many things. I just drilled a 15/16" hole in my bench and the base fits right in. The head uses a halogen tube similar to the work lights so it is very shallow. The switch is on the lamp head. It even has an outlet in the base you could plur a low watt tool into. Its $39 on the WEB, but I paid $34 in the store. "
The clamp has a 2+" opening and could grap something on your lathe. The arm is long enough you could clamp to the bed behind the tailstock.
Architect Lamp
Jennifer@Indy.USA
>Dennis,
Here's a picture from the Indyfest of our local club lathe and the swing arm light. I think it slips into the hole that the safety cage was mounted on. Hope this helps.
Jen
Mike Hamilton
>Second picture in Shop Shot 801 and two shots in the center of the attached page of thumbnails from Indyfest.
Regards,
Mike Hamilton
Plainfield, IN
CICAAW Indyfest Page 2
Jennifer@Indy.USA
>Dennis, I think a flexible gooseneck like a Moffat light would give you even more flexibility in getting the light where you wanted it.
Jen
robo hippy
>I like the Moffit lights also. Magnetic base, and 2 foot long bendable neck. I keep one on my headstock, and the other on the tool rest (PM3520A). One lights the inside of the bowl, and the other the outside. For spindles, I can shine the light from both ends.
robo hippy
>I love the Moffet lights. I have them with both the magnet and the quick release. I use the quick release for the lights that are around my mini because the wooden base won't take the magnets (although I almost always have a magnet one on the headstock).
I bought my lights from Gary Sanders of Texas. you might be able to look him up in the AAW directory. He was less expensive. He also sells a swiveling stand that bolts to the side of the lathe. it has 2 electrical outlets and a platform to hold a lamp. this has been one of my best investments and is a joy to use, light where you need it and electrical power to run drills, vacuum pump etc.
Re: Jet 1642 adding a swing lamp *LINK*
John Peck
>KestrelCreek has an article about Gary Sanders lighting and his web address here: http://www.kestrelcreek.com/Articles/Lathe_lighting.htm
GARY SANDERS LIGHTING
