Hollowing Punky Wood, Advice needed
Andy DiPietro
Andy DiPietro
>Does anyone have a good procedure for hollowing punky wood? I just read Leo Van Der Loo's posting on 8/17/06 using a 50/50 mix of water & glue on a punky bowl. Looks like the bowl came out great. Can that procedure be applied to a green hollowing? How thick do you leave the hollow form before soaking. Should you soak the piece or just apply the water/glue mixture to the outside? How long should you wait to return the piece? etc. Is it better to use Minwax wood hardener. Suggestions please.
Re: Hollowing Punky Wood, Advice needed
Wally Dickerman in Arizona
>In my opinion, life is too short to turn crappy wood. However,I have used the 50/50 white glue/water treatment on several ocassions. It has usually been quite sucessful. My method is to rough turn the piece, then soak it in the solution for about 24 hours. Longer might be better but I haven't tried it. After removing the piece I let it dry for days or weeks, depending on how wet it was. You're soaking in water, so it'll soak up quite a lot. As for how thick to turn it, remember that it will distort as it dries. An end-grain piece won't move as much as a side grain piece. One of the perks on doing this is that usually small to medium cracks will disappear. The wood swells, and you are soaking it in glue.
Good luck,
Wally
