Hollowing tool advice
LT
>I would like to try my hand at hollow forms...so many tools, so many choices. Anybody have any recommendations/favorites on hollowing tools?
thanks
LT
thanks
Home made...
steve antonucci
>If you have a lathe, you probably have everything you need to make you own tools...
You can buy steel rod from Home Depot or Enco if you want it to be prettier. Drill a hole in the end to accept a cutting bit and turn a handle. Look at Enco for bits too.
The whole shebang will be under $10, and you'll probably get 2-3 tools from the deal. Look at the catalogs to see what a tool looks like...
Steve
Re: Home made...
>I agree with Steve. I like the John Jordan set. Easy to use, nothing to go wrong with them and they work well. I made a set of tools that closely resemble John's using the same techniques that Steve mentioned. Bending the larger rods are the only problems. I use a mapp gass torch but to bend the 3/4" stuff you really need a forge or Oxy/acetelene
Re: I recommend the Stewart/Sorby ...
Jamie Donaldson
>....arm brace handle for control and less torque on your arm. It can mount a variety of commercial or homemade 3/4" shafts for hollowing.
Re: Hollowing tool advice *LINK*
Sean Troy
>I started out with a Cross Tip Tool by John Lea. I still find I go back to on a fairly regular basis even though I have a lot of other different hollowing tools. Check out his link. Other than John being a friend for a lot of years, I have no connection to Lea Tools.
http://www.woodturningtools.net
Carole Valentine
>I really like the Kelton Hollowers. You can do anything from hogging out the inside to a finishing cut depending on how you present the tool.
eliot d
>The first question you should ask yourself is how large will be the forms do you want to hollow. Also, have you thought about what size openings you prefer? These considerations will determine the size of the tools you will need. I started out with
3/4 inch diameter Dennis Stewart tools in his arm brace handle and moved on to John Jordan 3/4 inch tools, using the same handle, because I wanted to turn fairly large vessels with fairly large openings. I then began using various restraining rigs with lasers to help control the wall thickness. These days I tend to be turning somewhat smaller vessels through much smaller openings and find the 3/4 inch tools too large; so I made a few smaller tools from 3/8 inch diameter hardware rods. Most hollow form turners start out with scraping tools -- the ones that use a machinist's bit -- usually a straight tool for boring and two swan neck tools with different amounts of curve to hollow out the form and to get under the shoulder. Later , you may want to experiment with various other kinds of bits, like ring tools, that cut the wood rather than scrape. It's a brave new world! Have fun!
Darrell Feltmate
>It is a simple thing to make your own tools for hollowing. An Oland with a 3/16" tip at 45* and one straight will get you started. Add a couple of armbraces and for about $15 to $20 you are all set.
Around the Woods: Making Tools
Thanks for the replys...much appreciated
LT
Vicmarc.fan
>I am not a fan of Mr. Jordan but he is selling two 1/2"X12" tools now, one straight and the other hook.
