Vacuum Chucking Cylinder Seals
Bill Clark
>I just completed making a vacuum chucking system. I am using a Gast pump with a Holdfast Vacuum adapter through my lathe�s hollow spindle. I am pulling about 26 � hg at the end of the Holdfast hollow tube which is about the same at I got directly out of the pump. I�ve made three sizes of vacuum chucks out of MDF and PVC joint fittings. They have been sealed and the ends trued, and I rounded off the edge. The wall of the PVC is about 1/4�.
My problem is the seal at the end of the chuck. I purchased some 1/4� neoprene foam from Craft Supplies. The surface of both sides is rough and has no adhesive. For a test I cut a round from the neoprene big enough to over lap the cylinder walls and cut a large hole for the vacuum in the middle. When I attached two different bowls and tried to pull a vacuum I only got about 5 to 10 inches and the bowl was not secure enough to turn. The bowls were made of English walnut. One was 1/4� thick and the other 1/2� thick. I tried a flat piece of MDF with a 1/16� hole in the middle instead of a bowl and was able to pull about 20 inches of vacuum after I pressed the MDF really hard into the chuck cylinder. When the hole was plugged, I got about 23 inches. Next I tried some 3/8 wide by 1/4 thick vacuum tape (used for vacuum hold down jigs in the shop) on the rounded end of the cylinder. The results were about the same. I don�t believe the bowls were leaking that much air through the pores of the wood.
Is the contact area of the seals on the 1/4� rounded wall of the chuck cylinders just too small to obtain a good seal? I�ve seen many pictures of MDF / PVC vacuum chucks others are using and Craft Supplies even sells a kit to make them. What is the secret to getting a good seal? I would like to try some wider closed cell foam to wrap around the end of the cylinder. Can anyone give me a good source to order some? I have been unable to find any locally. Thanks to all for any help and suggestions.
Re: Vacuum Chucking Cylinder Seals
Bill Crommett
>Find a scuba diver with a worn out snagged wet suit. The closed cell foam makes great vacuum seals.
DD
>I've used the foam sheets that are used to wrap stereo equipment in when new. It is a closed cell foam and is thin and works well. I use it on my Nova vacuum adapter using a shop vac and it holds and seals well. I have glued it directly to a trued MDF vacuum face plate.
Doug
Re: Foamies or Funky Foam.
Al Crandall (NE of Indy)
>I use those brightly colored sheets of foam from the craft department at Wal mart or Michaels or Hobby Lobby. They are about 11 x 16 and cost about .79 each. Some of them come with self adheasive backs, but I buy the ones without adheasive and attach them with the spray I use for the 12" disc sander. A thin foam produces a much more sturdy mount than thick foam.
me too- called fun foam at Hobby Lobby
forgot to add message
>The fun foam sheets are also good for sealing then connection between the faceplates and spindle and in my case between the bearing and handwheel. If I suspect a leak somewhere the first thing I do is put a foam ring inside the faceplate(I have some short faceplates made from nuts and they don't bottom out on the flange where they should). In normal faceplates I'll put one of the plastic washers between the faceplate and mating surface.
>I bought sheets of Neoprene off a giant roll at an Industrial supply house. Look up gaskets in the yellow pages. The nice folks at the local Woodcraft Store actually put me on to this one. They had eighth inch and quarter and on up. I am using the eighth, and have not tried the quarter. I think thinner is better as mentioned above. Just thick enough to seal without being too spongy. Should pull up nice and firm, not rubbery.
I tried about ten other things like the foam that goes under laminate floor and the neopreen is the best.
Its handy to have it stuck on the cylinder, but not essential. You can just put it in place and let the vacuum seal both sides, but its easier if it is glued on.
Bill Clark
>Thanks for all the good advice. I'll get busy, try these methods and see if I can solve my problem. This was my first post on the forum but I have been following the Turning link for some time now. You folks are great! Once I get it all working I'll post some pictures of my set up for others to see.
Pete LaBelle
>You bowl may be leaking thru the pores. Vac chuck the bowl and run your hand over it. If it appears "sticky", that's the vaccum pulling on your skin. I've seen this tool. The first few minutes of sanding creates dust which'll get sucked into the pores of your bowl, clog them up, and you'll watch the vacuum pressure increase while doing it.
The craft foam others talk about is good stuff too.
Pete
Bill Clark
>Well I found the problem. I was sucking air right through the pores of the bowl. That's why the MDF blank held and the bowl didn't. I turned a new bowl about the same thickness, sealed it and it held fine. I had so much vacuum I had to open the bleeder needle valve.
I found the "fun foam" at Michaels and it works great. Thanks again for all the suggestions.
