Carpenter Ant question
David Breth
>Last night I brought home a couple pieces of box elder that had some smallish holes right around the pith (same wood I posted about earlier, but I did get a couple of checked pieces home last night). I got the chainsaw working at noon time today, and went back to get the rest of the wood from the stump. Got one piece in the trunk, one in the front seat. Holes in the pith were larger here, maybe 3/8". As I drove away, out popped a carpenter ant, whom I squished, and shortly after, out came another, whom I also squished. I then went directly to the dump, and disposed of both pieces of wood.
Then I drove home and put the two checked pieces I had from the before into a plastic garbage can. One of these was in my garage overnight, the other was immediately outside the garage. I pretty much store all my drying wood in the garage on racks, but these happened to be on the ground (concrete).
The pieces that I had overnight showed less sign of ant damage than the ones I acquired today (the hole in the middle was much smaller). On the pieces acquird today, you could almost see all the way through to daylight, on the ones last night, you really can't see through but you can see the presence of the hole at both ends.
So, my question is, what is the chance that I just introduced some friends to my house? Are carpenter ants the kind of guy that lives for awhile then croaks, and in the absence of a queen an individual isn't that big a deal, or is the situation more that an individual will live fifty years and will immediately get into everything?
I know precious little about these friends, and consequently try to be very, very careful about it. I didn't recognize these holes for what they were until adam ant came popping out to look around, which wasn't brilliant in retrospect.
Thanks -
David B.
Re: Carpenter Ant question
Keith Newton
>David, I don't worry too much about them. they don't eat wood like termites, they just like to live in it when the conditions are right, think moist. I kind of like what they do in some of the trees that I get.
If you want to keep the wood that you threw away, you can kill them pretty easy with Raid, Ant and roach spray. Just spray around and into the part that you will cut away with the chain-saw or band-saw, so you are not taking a shower in poison wood shavings.
Peter Hyde
>OK Keith
If they don't eat wood then what did they do to this maple?
I have had a lot of experience dealing with these critturs and believe me they are wood eaters. To establish a nest they need darkness moisture and warmth. With all 3 conditions to their liking they then build their own climate controlled environment to grew a fungus on which they live. The wood is eaten and digested to provide the fertilizer for the fungus. This was a small nest. I have seen them 8-10 ft. long in foundation beams where there is just a thin shell left of a 16" x 12" pine beam.
Scott Hurley in N. VA
>Chances are very slim that you got any in your house to do any damage. Not to scare you, however, but they do get into dry wood, and can do considerable damage, but they do need a nest as a base. We had them around the front door and front hall closet framing. You could actually hear them crunching the wood when everything else was quiet at night - really spooky. The exterminator came in, and used a metal rod like a stethoscope to find them. Then he drilled holes into the framing and squirted a pyrithrin (sp?) powder into the holes. No more carpenter ants. He said the nest was probably in the large oak tree in the front yard, so then we treated the soil around the house and the tree. I had to replace two of the studs and the header over the closet. When I pulled off the wallboard and the studs, there were dead ants all over the place. The pyrithrin powder is still in there, so if any more want to follow their ancestors, they will DIE, DIE, DIE!
David Breth
>I read a little bit about them after I posted. Apparently they get fed by the ol' queen directly. Don't remember what she eats, but I recall it is "smaller bugs". They definitely dig out holes in wood, but from what I read, they basically create tunnels in the and that's kind of it. The wood isn't a food source for them - which is kind of hard to believe when you see what they can do to a chunk of wood.
Please bear in mind that I'm posting at 2am, and only glanced at a quick reference I found on line, so this information is definitely incomplete.
Thanks for the posts/responses, by the way. I appreciate it. I try very hard not to introduce wood pests into the house, and felt like a moron when I saw those little dudes crawl out of the wood. Can't believe I didn't drive off the road.
don lewonczyk
>I burn a alot of locast and almost every tree I cut has them in it so I leave it out side until it goes straight into the heater. If they get in somewhere they will do damage. I think I have some in my camper between the ceiling and roof, there are little piles of wood dust where ever it can fall out and I've seen them around the entrance door. I'm going to fog them this week. You talked about going off the road when you saw them? Try having a mouse run up you pant leg while your driving a 1ton farm truck, that was exciting. Don L
Keith Newton
>Well Peter, I guess you have got me. I have never checked the intestins of a single ant, and I am sure that they use their mandibles to excivate with. whether they swallow or not, I could not say.
From the way you responded to my post verbally, it sounds like you would never bring it home. Yet I see that it is in your shop. I am puzzled. Did you just cut this to make a point, then throw it away, or did you use that wood?
My point was to not panic, and waste good wood. They are easy to detect, and get rid of.
Peter Hyde
>Keith,
Carpenter ants have been a pest to me for a long time. I have done a lot of house restorations and they are almost as bad as termites. Luckily we don't have termites in this part of Canada.......yet!
The wood was free and I had the ants crawling around in the Honda on the way home. 3rd or 4th time this year! So I go in to ant killing mode and pour gas into all the holes. After a few days I then split the logs and make sure there are no survivors. Normally the gas has all evaporated and the wood is usable. A lot of work for free wood but once in a while it produces that special piece and then it's all worth it.
Peter Hyde
>Scott,
thanks for the insight. I would however suggest that somewhere around your door there had been a leak and the ants were attracted to the damp wood. Once they start a nest they then create moisture to enable them to tunnel and excavate the galleries for fungus production. There is very little scientific info about these pests and most of what I know has come from personal observation. When a nest is dissected the tunnels stop abruptly in good sound wood. All around the nest is normally good sound wood so they have to be producing moisture to allow the softening and destruction of the wood cells. Nearly all the tunnels have black walls as if they are spalted. I have never found a huge queen as is normal in other insects and it seems as though all the ants are workers. They are also cannibals, and will haul bodies back to the nest to be eaten.
Re: or... a grasshopper!!! :o((
Allen Neighbors
