Advice Please....
Advice Please....
Advice Please....
Wally Dickerman in Arizona
>For a change, I'm asking for advice...
I want to purchase a small electric chain saw for shop use. It isn't practical to fire up my big saw just to trim a chunk of wood. So, my question is...what should I get?
Wally
Re: Advice Please....
Russ Babbitt
>You've probably read chainsaw threads before. Stihl / Huskavarna. I recommend Stihl for a gas saw. I also have a Stihl electric for around the house. I did have a "hobby" electric for a while and it worked just fine, just does not have the power the Stihl has. Maybe others will recommend brands. I would say buy the best you can.....
Mac
>Hi Wally, Dont have one myself YET,but after loooking and asking around,it appears to me that the Husky is one of the better ones. Problem is, they cost almost as much as a gas saw.Have friends that have bought the cheapo ones and all seem to regret it.Good luch...Mac
Wally, I have had 2
T Daniel
>My first came from Sears....I gave it away. My current electric is a Husky, made by the people that have made Electrolux vacuum cleaners forever so I figured they might know something about electric motors. I have had no problems with it and it has plenty of power. I had the dealer replace the anti-kickback chain with regular chain before I brought it home. Some other brands you might want to check out are Makita, Milwaukee, and Stihl. I think you are looking at spending about $200 to $220 on any that are worth owning.
TD
Brodie Brickey
>Wally,
I received an electric polesaw. The small chainsaw detaches from the pole and I can use that in the shop. If you're just trimming a limb off a blank I don't think you need much. If you're going to chainsaw sculp, or do a lot of fine trimming something better may be necessary.
I don't think the polesaw cost more than $100. You mentioned you already had a good gas saw, but needed something for the shop. I assume your talking about quick trims as opposed to dragging in a large log and cutting it up. Is that correct?
Brodie
Bill Grumbine (Kutztown PA)
>Wally, did you think about trying one of those Lancelot carving tools that go in an angle grinder? They are pretty much a round chainsaw. I don't know if it would give you the trimming capacity you need or want, but it might be worth looking into.
Bill
Bill Neddow
>As others have said, Husquvarna or Stihl. I inherited a Remington. Plastic gears. I bought a Makita. No way to tension the chain. Next tool I buy is the big Stihl electric. It uses the same bar and chain as my small gas saw. I don't think you will need anything quite that massive, though. I will be using it to balance 2 foot diameter rough bowl blanks. I am sure the smaller Stihl, or one of the Husquavarnas will work well on the sizes you work with.
Brad Vietje
Stihl
Brad Vietje
>I have an older Stihl E20 (pre-unification since it says Made in West Germany), which has great power and is always ready to go. I got a steal on this Stihl since I bought it used from a lawnmower/small engine repair shop for $ 50.00 with two brand new chains included -- one crosscut and one for ripping. I think $100 would still be a very good deal for a used one in good shape. Mine has a 20" bar (and can handle it), but it might be handy to have a smaller bar for blank trimming.
Regarding Bill's Lancelot idea, I have heard from people who've tried them (I have not) for carving and texturing that they are fabulously dangerous -- I think treacherous and life-threatening were the words of choice. A friend and fellow turner uses the Arbortec for his carving, which is much safer -- wouldn't be great for trimming blanks, though.
Safe spinning,
Brad Vietje
Newbury, VT
>I had a Remington I bought at Lowes and trashed the plastic gears pretty quickly. Bought a Sears, also about $89 and Paid $12 for a two year replacement warranty. I couldn't afford the Price of a new Stihl electric, about $350. The Electric does real well if you don't dog it and at $90 I can treat it as a disposable. If I found a Stihl for under a hundred bucks I would jump on it, its another whole class of tool.
Thanks Folks...
>I have a good idea now on what to shop for and what not to consider. I want a saw to do a little more than trim corners on a blank.
Wally
gil jones
>Wally, I have a Poulan 16" electric that I have had for at a long time (10+ years?). It works ok for trimming, but leaks bar oil faster than I can use it. Still, it was not expensive (less than $80), and I just installed the first replacement chain a couple months ago. It cuts OK, but is not very powerful, and I could not recommend it to anyone.
Gil
Brian Hahn in SW Wisconsin
>I bought a Makita electric chain sat this summer for about $200 and I've been very pleased with it. It looked comparable to the Stihl, but the local Stihl dealers don't stock electric saws so I couldn't do a real comparison.
Interesting, the Makita was made in Germany.
Mine leaks oil too, don't put much in it.
Re: Advice Please...., Milwak...
David Staeheli
>The absolute best electric chainsaw I have ever seen was the Milwakiee (sp) that my brother-in-law owns. Heavy as sin, but tons of torque. Cannot dog it down! Unfortunately, they don't make it anymore. But who knows, maybe E-bay? Now to talk by brother-in-law out of it.
Ryobi a great value and it has held up
Jerry Hall
>Last April I posted the following and it is still true. I think the Ryobi is a great value. Only issue is having to clean out green shavings every so often, but that is true of most saws I think.
For low cost and great performance:
Ryobi RY43006 18" 13 amps. Got it from Lowes for under a $100. Has worked great for cutting my logs and blanks. Quiet, no smell, in shop use, and easy startup is sure a pleasure. I find I use this more and my band saw less. At first I thought the 18" blade was a bit long, but have come to appreciate it on many occasions. It is safer to keep the tip out of the log, and the 18" helps a lot there.
I have heard that Stihl is the gold standard, but at 3 times the cost so far I don't know why I would go there. Ryobi does the job perfectly for me. This model had the most power of the lower cost products, which I believe makes a big difference.
The full, excellent, thread is in the archives at:
http://www.woodcentral.com/cgi-bin/archives_turning.pl?read=109176
And for Consumer Reports opine....
Jerry Hall
>Here is CR's take. I am not sure how it comports with the feedback from this forum, but FWIW:
http://www.consumerreports.org/cro/home-garden/safety-security/disaster-preparation-10-06/ratings/chainsaw/1006_home_ratings-saw.htm
Tip I Learned
Ron McKinley
>Was out shopping for chainsaws awhile back and started talking to a fellow customer. He seemed to know a lot about chainsaws so I asked his advice. One thing he told me was to always loosen the filler cap for the bar oil when you finish. Says they stay pressurized for hours after you shut them down and if you loosen the cap slightly to release the pressure and re-tighten it won't leak. Works for both gas and electric......Ron
