Grizzly 1495 lathes
Grizzly 1495 lathes
Grizzly 1495 lathes
Frank of Mantua
>What are your opions on the Grizzly lathes.
I am looking to buy a lathe and was looking at one.
Re: Grizzly 1495 lathes
Allen Neighbors
>Frank, I have a Grizzly G5979, 12" swing, 36" bed. Tailstock doesn't line up with the headstock, unless you monkey with it. Can't do that when you have a bowl mounted. Mine has a gap bed, which isn't too cool when you need the bed to be where the gap is. :o) Moving the toolrest too close to the headstock... for really small pieces, and it will fall into the gap.
The toolrest is all made of cast iron, and I've broken 2 or 3 of them, so I JB welded a 3/4" rod across the rest. The banjo is cast iron, and I've broken two of them. Just keep replacing them.
The motor is marked a little heavier than it actually is, but has run perfectly otherwise, for about 2.5 years.
The fit and finish isn't as fine as a more costly lathe, but then you get what you pay for, there, don't you.
Mine has a reeves drive, and I keep it cleaned and oiled, and it hasn't given me one ounce of trouble. I don't like the fact that you can't get it slower than 250 rpm.
Mine has a swiveling headstock, and the knob that locks it has broken once.
Other than these minor things, it's been a good lathe. I still use it for sanding, and some finishing, and think I'll be using it to turn collars for hollowforms while the form is on the big lathe.
Hope this gives you some info to peruse.
Allen
Bob Fawcett
>You can get a Jet for about the same money. Look at the 1442 or the 1236.
Jason Clark
>Frank, If you're looking at a Girrzly make sure you lLook into the G0462. I've had my G0462 for about 9 months and while it doesn't have the fit and finish of a Oneway or Jet it is a heck of a lathe for roughly half the money of the G1495.
Jason
