Veritas - Innovation in Tools
band saw blade guides
jared
>I use timberwolf blades on my Delta bandsaw that has the riser block on it. The blade guides that I have on it now are cool blocks, mostly because I put them on a long time ago and now I cant find the metal ones that came with the saw origianlly. It seems like the cool blocks wear off at an angle quite quickly, from the twist on the blade when cutting my turning blanks. As a result the blade doesnt really have much guidance or support from the blade guides. I cut mostly ash that is green and wet. Will the Carter guides, the ones that are all rollers, work or would they just gum up and plug up from all of the wet wood? What do other people use for guide blocks on their band saws? Thanks in advance Jared
Re: band saw blade guides
Kirk (KC) Constable
>I put Carter guides on my old 14" JET, and it was a different saw. I hate Cool Blocks, and the metal things. I never noticed anh gunking up.
B. Leathers
>Another alternative that is also economical are hardwood blocks of the same dimension as cool blocks . Soak them first in chainsaw bar oil. I believe mine are white oak - cannot remember how long ago they were replaced ! B. Leathers
>I have "Band Rollers" from Iturra Designs. They were cheaper than Carter guides and are working well for me. I have no experience with Carter guides, so they could be even better. The band rollers are tiny ball barring mounted in piece of metal that mounts right where the cool blocks mount, that is, in the original guide mounts. I bought a number of things from Iturra and if you don't have their catalog, you should.
One thing I like about the rollers is they are not fussy to set up. Just press them lightly to the blade and tighten the set screw and they were dirt simple to install. Nothing to change.
Ron in Drums PA
>I just started using lignum vitae as guide block, before that I was using maple.
Both work well
Keith Tompkins
Keith Tompkins
>Hi Jared, a couple of thoughts....what BRAND of cool blocks are you using? There is a big difference. My genuine cool blocks are over 15 years in service. For precise work,with fine blades, cool blocks excel, as they give a lot of support to the blade. They may need to be dressed on the grinder occasionally, then set up properly.
Here's my procedure: track and tension the blade, trying to center to blade on the tires....that's important. Then, set the rear rollers, both top and bottom until they touch the blade while running. Touch lightly, but barely, barely rotating. That way, the pressure of the cut does'nt force the teeth backwards into the cool blocks....ruining the face of the blocks instantly. Set the cool blocks last. I use a piece of ordinary lined notebook paper between the blocks and the side of the blade..apply even pressure, then tighten the set-screws.
The carter rollers are a good investment, but they require the same care in installation....they will be wrecked by the bandsaw teeth coming into contact with them in short order.
There is a fine woodworking mag with an article on this subject...don't know which one....
Peter Hyde
>Keith,
A dollar bill is the normal thing to use for setting up the rear bearings. Cool blocks should be in light contact with the blade to provide maximum support and prevent twisting.The must be set behind the teeth gullet to work properly.
My cool blocks are from Lee Valley and going on 20 years old. I thing I have dressed them twice. Mark Duginski's Bandsaw book has a lot of good info on guide set up.
Bruce in Saint John, N.B. Canada
>Keith, I believe the article you are refering to in Fine Woodworking was titled "Choosing Bandsaw Guides". The article was published in the March/April issue, page 36 and I must say it is a most informative article and well written
>Sorry, forgot to put the year in my above posting, 2001.
bob davis
>ialso made mine from white oak..very durable. when they wear only takes a moment to square them up on the disc sander
Hooligan
>I tried the Laguna guides, and I will never again own another. They are relatively spendy, but well worth it for me. Not any different than the carter guides, pricewise, so I thought that I would give them a shot. Glad I did, too.
Square up the face of the guides...
Brian Hahn in SW Wisconsin
>I square up the faces of my "Cool Block" guides every once in a while. I use a disk sander (stationary) and lightly touch the face of the guide block to the sander, rotate the block and repeat until the face is once again flat and true. I saw a lot of green wood and have never had a problem with the guides.
Keith Tompkins
Keith Tompkins
>AHA! I was using a quarter! Mayabe that's the problem. LOL
Keith Tompkins
Keith Tompkins
>Peter, I always set my rear bearings with the saw running, because I want the blade skimming against the bearings. A static setting isn't accurate enough; often the blade moves slightly after starting, requiring resetting the bearings anyway.
One thing I didn't think about, however was the fact that I'm making a adjustment to a running machine.....in hindsight, I must caution anyone attempting this procedure to use extreme caution. It that light, your dollar bill idea is probably a good way to go.
I neglected to mention setting the cool blocks back enough to clear the rake of the teeth....thanks for mentioning that.
