Ornament prices
Ornament prices
Ornament prices
WOODNUT358
>Just wondering what some of you charge for the hollow xmas ornaments with the icicles? These are around the two inch diameter,maple,walnut,and cherry.Thanks.
Re: Ornament prices
Re: Ornament prices
>I get from $25 to $45 but the $45 dollar ones don't sell very well even though they take a lot of time and I'm probably losing money on them. Around here $25 and $35 go pretty well. I sell my 2 part hollow ornaments for $25 but I can make 2 or 3 an hour so they are good money makers for me. I've been working on a way to make the Birdhouse ornaments much faster. People seem to like those but it seems like $25 is about all I can get in this market so I need to make them quickly.
Re: Ornament prices
Re: Ornament prices *LINK*
Darrell Feltmate
>John
I get a little under $25.00 for a ball and icicle and $15.00 for a bird house so I make them fast. For a bird house start by turning a 1" diam x 1 1/2" long tenon on a piece of scrap on a faceplate. Take a 1 1/2" sq block and drill out the inside to a depth of 1/2" with a Forstner bit. The block goes over the tenon. Turn the body to 1 1/4" diam and taper/decorate the bottom. In contrasting wood turn a top with a 1" diam x 1/8" tenon and super glue it to the base. A 1/4" hole in the body and a 1/6" perch and done. One of these days I will do a batch and get it up on the site.
Around the Woods
Re: Ornament prices
Re: Ornament prices
Mike Brazeau
>Great idea Darrell. Our Hands-on this coming Thursday is on ornaments. I have clipped and put in my ever growing file to take with me for our discussion.
Mike
Re: Ornament prices
Hijack, how I make them.
>John, I cranked out a batch of bird houses recently. I had an 1 1/4" router bit with a round nose (core bit?) and a half inch shaft. I'm using it as a bit that drills a round bottom hole.
I cut blanks that are about 1 3/4 or 1 5/8" square and 2 to 2 1/2" long. I chuck the blanks and use a Jacobs chuck in the tail stock and hollow the inside of the end of the blank. Then I turn the blank down to round and about an inch and a half in diameter, leaving the walls about an eighth thick. The end of the blank in the scroll chuck is still square. I make a bunch of these.
I made a bunch with an "A" roof. I take the blanks above and turn to my bandsaw. Using the miter gage set at 45 degrees, I put the square end of the blanks against the miter gage and saw off the end I hollowed, flip it 180 and saw it again, creating a mitered opening from the center.
I made a mandrel the same size and shape as the core box bit and I put that in the same chuck and jamb chuck the blanks on it and cut away the square bottom and put a "drop" or Icicle or decorative bottom. I bring up the tail stock to hold it and sometimes at the end I tape ti on with blue tape and remove the tail stock. I found that if I made th mandrel out of something solid like maple and mark the exact orientation of the jaws I can use it over and over, removing and remounting it. If the bird house is a little loose, I wrap a piece of tape around it.
I have a similar mandrel mounted horizontally on a little "shoe" (?) I clamp on the drill press. I slip the bird house on it and drill the hole. I have hand drilled them by eye, but I broke some because they were pretty thin.
For a roof, I use two little piece of wood about the thickness for veneer. Well maybe a 1/16 or 3/32". I pick up scraps of whatever and resew them on the bandsaw and either sand them in the Performax or just on my belt sander. Lots of possibilities. Square roofs, Prow shaped roofs, round roofs. I drill a little hole in the top of the ridge with a pin vice and glue in a "eye" with CA. I glue the roof on with CA.
I also make the blank the same way and do not angle the top and turn any number of different tops.
I would post a picture, but the person I made them for took them all and I don't have one at the moment. The core box bit seems very worthwhile. It is quick and makes the interior consistently he same size so that reverse chucking is consistent and quick.
Re: Ornament prices
Lynn Edwards
>John; Recently I helped a member of our club create a "how to" on his method of making ornamental bird houses. With just a couple of home made jigs, even I can make these fairly quickly.
How to turn a birdhouse
