Light wood and pen bushing smear
Marianne
>I've noticed [to my irritation] that pens I've made out of a lighter wood color that pen bushing debris makes a dirty band on the pen edges near the bushings. How can you prevent this? I've tried to be very careful not to sand over the bushings and also not to *turn* the bushings! It seems to occur when I start applying the friction polish. Any recommendations are greatly appreciated. Marianne
Re: Light wood and pen bushing smear
RevDoug
>Always apply your finish toward the bushing. A common mistake is to go beyond our wood onto the bushing and then drag our finish back onto the wood. This allows your rag, towel, what ever it is that we applying our finish with, to pick up any metal debris and redeposit onto the wood.
Turn 'em round,
You were watching me!
Marianne
>That is exactly what I have been doing. I do lift when I go over the bushing but it probably was not enough and allowed my polish cloth to pick up debris. I think what I need to do is insert additional spacers so that there is a pronounced free space between my pieces of wood. Appreciate the advice! MA
George (Oxford, NC)
>I have not (yet) but I have heard of those that have turned their own bushings out of Corian. Corian should stop any bleed. Having had the same problem, I may have to get some Corian and try it myself.
George
Ron in Drums PA
>The trick is to sand up to the bushing, but not on the bushing itself.
Try applying a little sealer (or some of your finish) to the wood (and let dry) just before sanding. This seals the wood and helps prevent the debris from getting into the pores of the wood.
Don't forget to post some pens when your done.
Bill Grumbine (Kutztown PA)
>Marianne, another strategy which I have used, is to put some finish on the bushing itself, let it harden, and then go on to finish the pen with a clean part of the rag. This has the effect of trapping any dirt that is on the bushing where it is, and lessens the chance of getting it on the pen itself. Good luck with it.
Bill
Re: Light wood and pen bushing smear *LINK*
Darrell Feltmate
>Marianne
I like Bill's response (thanks Bill, again). One thing I do with pens, dark as well as light, is to "wash" them before the final finish using a mix 50/50 of mineral and vegetable oil. Just put it on and wipe it off with a facial tissue, dry at speed and apply the finish. I have not had a problem with any finish following the wash and the dust is cleared. I turn a lot of bird's eye maple pens and this works well for such a light wood.
Around the Woods
Thank you all - great recommendations
Marianne
>I have a few pen blanks ready for turning this weekend and look forward to trying the new techniques. Thank you all again for taking time to respond and your advice. Marianne
