We value your privacy.
>My last bandsaw blade... that I installed... Tuesday, I believe, is broken already. I mentioned that it was knocking like a banshee... well I was cutting a 2" thick piece of Bois d'Arc to make a screwdriver handle, and it broke... by the weld. I'm pretty darned irate. That's all five of the Highland blades.. the two that JL got me in April, and the rest I've ordered since then. I'm not ordering any more of them. :o(
>I've not had good luck with them, either. I tend, now, to stick to Olson. I get them a LOT more reasonable than HH, or Twolf, and for me they last just as long.
>I bent two of the Highland hardware blades in nothing flat. I know a lot of people like them but I won't buy one for green wood anymore. I use $6 blades from my local saw sharpener. They cut just fine and last a good while. I don't even sharpen them I just toss them when they get dull.
>I don't like their blades either---or the company either for that matter.
I got one of the bandsaw repair kits a few years ago. It's about $25.00 as I remember. A little jig and some solder with flux and instructions. You need a small grinder and a bern-z-omatic torch The thing works great. Saves blades and running up to the store. I have even bought bigger blades on sale and cut them down.
Re: Well, I broke the last blade today. :o( *LINK*
Darrell Feltmate
>Allen
May I reccommend http://www.tufftooth.com , that is R&D Bandsaw in Otario, Canada. Great product, price and service. No affiliation but a very satisfied customer.
>Al, if those blades are not bent/mangled, take them to a good machine shop that has a bandsaw blade welder, and see what they will charge to weld them back together. I also believe I would be bending Highland Hardware's ear big-time.
>those sound really good to me. The Silicon band with tungsten silicon chrome added sounds just like the Timberwolf... and at less cost. I'll give them a try. Saving this link.
>Gil, I've already ordered a couple of Timberwolf blades, and don't even want to mess with it any longer... don't have time to fool around with that stuff.
>Those blades from Highland Hardware are fine when you use them for what they are made for. The teeth are cut to work with air dried or kiln dried lumber not wet , fresh cut wood. Use it for that and the teeth get clogged with wet sawdust etc and it won't be long before the stress and excess heat breaks a good blade. They are working on getting a blade out specifically for wet wood users like turners. I will be standing in line to buy mine.The right tool for the job and there won't be any problems. Leave the blades you have now for resawing on the bandsaw, especially those little 1/2" blades you have.
>I once worked in a machine shop. The large bandsaw we had came with a blade welder built into the machine. I can't remember what brand of saw we had, but I bet that was not a unique feature.
>Mitch, I've only had one 1/2" blade in the 16 years I've had this bandsaw. I still have it. I've used it once. Most of those years I used either 1/8" or 3/16" blades, because most of what I cut was cured wood, making bandsaw boxes.
When I started turning less than 3 years ago, I still used the 3/16" blades, up until I went to Georgia last April. Then I went to 1/4" and 3/8" Highland Hardware "woodturners bandsaw blades". They aren't as good as the Grizzly Blades, in my opinion.
Also, very seldom do I attempt to cut 'wet' wood. Most of my wet turning blanks are shaped with the chainsaw.
Most of my breakages, and the one that broke my last blade, happened when I was cutting pieces less than 3" thick, and not forcing it in any way.
Also, if by "resawing" you mean making narrow pieces out of thicker pieces, I've not had a need to resaw.
>Mitch, that blade IS the one HH developed for turners. We got them when they came out in May. Their description:
"Creating bowl blanks from green wood on the bandsaw can be taxing for standard blades. Many of our customers, happy with our Wood Slicer� Resawing Blade when cutting kiln-dried lumber, have asked us for a worthy blade to handle the difficulties bandsawing green wood.
Our 3/8" wide WoodTurner's Bandsaw Blade, with its 3 TPI, alternate set w/raker tooth pattern & stout band thickness of .032", is just the blade for the task. The significant tooth set of this blade provides ample room to keep the blade zipping along through dripping wet, kerf-closing, growth-tensioned logs. The deep, rounded, hook-toothed gullets allow chips to be easily removed from the kerf enabling quick, aggressive cuts."
I never used mine because even though it is supposed to be 105" band, I was nerevr able to get it on my saw.
