Band saw Storage
Band saw Storage
Band saw Storage
Leslie S
>Due to circumstances beyond my control I will have to store my bandsaw in my unheated garage for the Winter. Are there any steps I should take to keep spiders (or the chipmunk that lives there also) moisture, etc at bay? I plan to raise it off the ground on a pallet and cover it well. Any suggestions?
Re: Band saw Storage
Don in Central Illinis
>You could store it in my heated shop. I'll take real good care of it, since I'm in the market for one anyway. Hee hee.
Leslie S
>If you were closer I would take you up on that!! :)
Jim Pugh, Elyria, OH
>Guess I would put a good coat of wax on the table surface. Then you should be good to go.
Carol from AZ
>Keeping rust off ought to be the easiest. Heavy wax application wherever it is necessary. I would certainly begin with a thorough cleaning and lubing. Leftover saw dust is P&P litter to critters. If you have cats you know that to be Pee & Poop litter! And don't forget to remove the blade.
That should discourage everything but the spiders, and if someone has solution for THAT, I am all ears.
Roger
>Take tension off drive belt.
>2nd the car wax idea. Another thought. How about "shrink wrap"? If you clean it, wax it, detension the spring, etc. If you were to wrap it in shrink wrap (don't use Saran Wrap, use an EVA or mPE based wrap) - it might keep the spiders at bay. I don't know if the chipmunks would eat through it though.
I would clean it and
Don Henthorn
>wipe all unpainted metal parts down with an oil soaked rag. Next soring wipe it off and set it up again.
Re: I would clean it and
Pete LaBelle
>Caution on the shrink wrap. If the garage can/will be damp, it will draw moisture. Wax/oil/grease the raw metal surfaces & cadium plates surfaces, loosely cover with a piece of plastic or tarp to reduce exposure to the damp air in the late winter, & hope for the best.
Bill White
>Wax, detension, clean, cover so it won't sweat. You'll be good to go.
Bill
Leslie S
>Sorry I didn't get back sooner. Thank you for all the suggestions!!!!!
