We value your privacy.
>Where can I get one? My wife purchased the entire OneWay vacuum chuck system for me when I retired but now I'm thinking I need a filter to trap moisture and other gunk.
>Would a moisture filter system used on air lines work?? My vacuum system uses several reservoir chambers and a sub reservoir so I haven't really worried about it getting to the pump. Maybe I should?
>I don't think water is a problem. Water vapor pressure is very low under vacuum and would not be present in the liquid state. It may exit the exhaust as liquid though since it would be at atmospheric pressure then.
>Best I know is the vacuum pump is used on A/C systems to pull a vacuum and remove moisture from the system and no moisture trap is used in that application so I don't think it's needed. I have the oneway system and use an air filter on the intake and a inline gas filter on the exhaust port. The reason for the filter on the exhaust is the carbon vanes in the pump wear down and the particles(carbon dust) gets trapped, instead of shooting into the air and messing up the shop etc. Or else hook up a air connector to the port and vent it outside with a flex line 1/4" I.D. My system works great, when I first wired it up to make sure the pump would work no plumbing was attached on when I turned it on black powder shot out the exhaust port in my face. I got the pump from Surplus Supply for $89.99 plus shipping and it's wired for 220v. The filters you can get from an auto parts store. Hope this helps. Don L
>Yes, I also have that mounted on the intake of the pump body but in addition I have the little air filter out at the intake of my plumbing where my control valve is. Works for me. DonL
