We value your privacy.
>I want to turn some bed posts from some red oak branches that I have (6" to 8" diameter about 4 feet long). They are green and have the bark on and end sealer applied. Should I let dry for some period before turning or do I rough turn and then let dry, or do I go ahead and finish turn and apply a finish to help seal? These do not have to be 'high grade' furniture quality but if that is possible then all the better. Any insight would be greatly appreciated. Thanks.
>Steve's got a good point. In general, a full diameter of a branch or trunk larger than about 2"- 3" or so, will crack from the outer edge under the bark, toward the "pith", or center of the growth rings. This can result in one large split, or several smaller ones. If this sort of look is what you're after, you may be able to create a cool looking bed, but it will certainly look "rustic" or "deer camp". If a branch grows straight up, the pith will be centered -- if the branch grows away from the trunk at some angle (as most do) the pith will be off center. The cracks will most likely happen wherever the pith is closest to the bark -- shortest path and least resistance.
If you want turned Red Oak legs that are stable and will resist cracking, you probably want them cut off to one side of the pith from larger stock -- generally the further from the pith the better. If you REALLY want to use the pieces you already have because they have special value, you might get away without cracks if you hollowed them out by boring away the pith and the central 1" or so of the branches. You could then turn balls or some other shape out of solid wood to cap these hollow bed posts... just a thought.
>Are you expecting to keep them near the 6"? As Steve said, they might move on you. I've turned maple log sections for legs, and had them go a little "oval" on me. I tried turning a couple of thinner (3-4") branches. The results were not pretty. I got interesting "features" where the much smaller branches came in. I also got a little warping. I was taking them down to about 1 1/2".
>Thanks guys. These pieces of wood have no special value, only that I have them available. I don't mind checking and such but I don't wnat full size cracks. I have some larger logs I could saw up and it sounds like that might be the better idea. I just didn't know if what I had would work or not and was looking for advice. Thanks.
>Terry You will definitely get some checks unless they are totally dry. Even wood oak that doesn't have the pith will probably check mostly because it's very dry in the house. It would take years for the wood to dry. I needed to turn some large table legs so I went online and bought some legs from Osborne woodworks. I made sure the dimensions of that leg were such that I could re-turn them when I got them. It was cheaper doing that than buying the dry lumber in the dimensions I needed. Of course that wouldn't work for all shapes.
>I just turned some bedposts. I made my blanks from 8/4 rough lumber. After jointing and planing I ripped a 7" or wider board in half and laminated the 2 halfs to get a blank at least 3 1/2" square. After the glue dried, I planned all my blanks to 3 1/4" square. The glue joints have almost a "book match" look since both pieces came from the same board. The joints all but disappear once turned.
Is there a way you can saw the logs down the centre and then coat the cut surface with Anchorseal? I have done this with short limbs and it stops serious cracking. I let them dry for about a year and then passed them over the jointer and glued them back together. After turning and finishing the joints were invisible.
