Turning a Table Pedestal
Mark McC in Whitby
>I am planning to make a 5-6" diameter table pedestal based on a commercial one we bought years ago. Main concern here is safety! My pedestal plan is to form a hollow 5-6" diameter Octagon about 2 feet in length overall,then round, sculpt and do some beading in the centre section. Is turning this segmented Octagon way safe? I am a bit concerned about the thing blowing out. Also how would you attach it to the lathe. I am thinking about just covering the ends by screwing in two flat removable octagonal covers, as you will never see the ends. Again my main concern here is safety, any tips, things to watch for or different approaches appreciated.
Mark
Re: Turning a Table Pedestal
>Shouldn't be a problem at all as long as you make the segments thick enough so you don't cut through when turn a cove shape. Make sure the glue joints aren't starved. I glue waste blocks on both ends for both safety and to give me centers to work from. If you get nervous about blow out simply wrap a few layers of nylon strapping tape around each end or the middle. You can do this before and after turning if necessary. I do this on large inside out turnings to stabilize the turning so it doesn't vibrate as much.
Jim Pugh, Elyria, OH
>Mark, turning the pedestal on a lathe will be quite safe - just operate at a reasonable rpm. If you are worried about it blowing apart, put a couple of hose clamps around it toward the ends and/or where you aren't working at the moment.
Instead of making octagonal drivers, just turn some tapered cones to fit within the octagonal opening. Mount the driving end cone on a faceplate and leave a shoulder for the column to butt against. Make the tail end cone with a center hole that you can run your lathe tail center into. Using the cones will allow you to dismount the piece if necessary and put it back with a minimum of alignment problems. It will also allow you to reverse the piece end for end which may prove to be helpful.
>As others have mentioned, make sure your octagon is made of wood thick enough to "contain" the circles you want to turn. Draw up a full sized model of the end and the use a compass to determine the maximum and minimum size you can "get".
Mine was between eight and ten inches in diameter and what I did was cut a rabbet in the ends of two of the stave's. I inserted a piece of wood that ran across the end. A piece about 3" wide and an inch thick. In one end I drilled a hole that would accept my spur center (about 1" in diameter and 1/4" deep. In the other I drilled a smaller hole for the live center. I could have just loose fit the pieces in, but I glued them and used them later for mounting top. (Drilled a 3/8" hole right through the center and used a piece of all thread rod. the nut recessed into the hole for the spur center, so that was the bottom.)
Thanks... great tips too!!
Mark McC
