Veritas - Innovation in Tools
What size blade???
What size blade???
What size blade???
KurtK in Indy
>What size bandsaw blade do you use most for roughing blanks to go on the lathe? I usually cut up green wood. I have an 18" Jet.
Thanks for the replies.
Kurt
Re: What size blade???
Carole Valentine
>I use a 3/8" 3 tpi
Re: What size blade??? *LINK*
Mike Cunningham (Cape May)
>3/8" 3 tpi. I use Timberwolf blades intended for green wood bowl blanks and buy them from Suffolk. If you tell them the make and model of your saw and the intended use of the blade, they'll fix you up. See the link
Suffolk Machinery
Tony Reynolds somewhere near Newark, Ohio
>Timberwolf 1/2" 3tpi AS. It's made for cutting thick green wood. Best blade I've used for this app.
Tony
Yep...that's the one.
KurtK in Indy
>That's the one I had before I chewed into a nice nail embedded in a burl blank. I didn't know if there was anything better. I'm pretty happy with the TimberWolf.
Thanks.
Kurt
Looks like I'll have to try..............
Ruth Niles
>those 3 tpi blades again. I tried one once and it scared me; and I don't scare easily. Those suckers really grab.
I usually use a 1/4" 4 tpi for everything because they're so safe but guess it's time to add spice to my life.
Timberwolf are the only ones I use, too.
Re: Looks like I'll have to try..............
>Ruth I'm been too lazy to remove my 6tpi 1/4" blade so I just used it anyway and I've cut about 8 bowl blanks for myself and my current student. I just have to feed it slower.
Eric
>I have used a couple of these 3/8" 3tpi AS Timberwolf blades. I didn't get much life from them even though I remove as much bark as possible before bringing it to the BS. I bought a couple of the Woodslicer green wood blades and have only a couple blanks cut with it so far. It is too early to provide a fair comparison. What kind of blade life you your folks get? Thanks!
3/8" 3 TPI
Ron in Drums PA
>Brand is not important
bob davis
>ruth, ihave used the 3/8-3 timbrerwolf for years..best i have ever found..also i resharpen upto 4 times unless someone does something stupid and destroys it///bob davis
I'm Different, I guess....
Hooligan
>I like a 1/2" 4 Skip, or raker. Depends on the species of wood that is prominent in my stash when I am buying bands.
Terry Quiram, Roanoke Illinois
>I am usually turning pretty large blanks so I can get by with a 1/2 3tpi. Besides I don't care if they are round, I just knock off the corners.
Terry
Dick Hines
Re: 3/8" 3 TPI
Dick Hines
>3/8" 4 TPI Hook. and like Ron I use what I can get. Cutting wet wood is going to screw it up sooner or late anyway. Just make sure you cut with the flat side of the blank faceing down, on the saw table.
Re: Eric, Life? Not much ....
Allen Neighbors
>I haven't gotten much life out of the last blades I bought. I bought those special blades (from Highland Hardware)that are supposed to be for woodturners. I bought the 1/4 X 3tpi, and they haven't lasted as long as my Grizzly 3/16 blades.
Others have suggested that I get the 3/8" or 1/2" blade instead.
But they must have had a trainee in their welding department, because I broke another one today, and when I put my last new one on, it knocked like an old Ford. I checked the weld, and it really stinks. I don't know what I'm going to do... probably go with the TimberWolf. I'm tired of wasting my money.
Peter Hyde
>Allen get yourself a silver soldering kit like the one from Lee Valley. So you lose maybe 5/8" of length but they will still be usable. I find my breakages have dropped to 0 since I started silver soldering my bands from bulk lengths. Most cheapo brands have not had the welds annealed and so there is a brittle area each side of the actual butt weld and that's where it breaks.
Re: I'm Different, I guess....
Ruth Niles
>Only thing is you can't cut as close a curve with a 1/2" as you can with 1/4". Like John Lucas, I'm lazy and don't change the blade until it simply screams with each cut. Also when a blade gets a tick (bend), that blade lasts longer than any other one!
Hooligan
>This is true. Though, the majority of my blanks are over 8", otherwise I just knock off the corners, and call it good.
Darrell Feltmate
>I use a 3/8" 3tpi for bowl blanks, usually from http://www.tufftooth.com Great service and product and I am just a satisfied customer.
That said I generally just knock the corners off the blank with a chain saw if the bowl is over eight inches. Under that I may take them off with the band saw but I am as likely to do it on the lathe. That way I get to decide if the bowl will be round or square or whatever.
