A55 Smoothing Plane
Spindle Blanks
Spindle Blanks
Spindle Blanks
David Breth
>Hi -
I find myself in need of spindle blanks, ranging from 3" diam x 6" long to about 6 diam x 12 long". Wood type is unimportant, these don't need to be anything special except dry, though I would like to utilize a variety of woods.
My purpose is that I'm hoping to do one or two local craft shows in the spring, (which would be a first for me), and I've got a variety of trinket stuff in mind to do over the winter.
Any recommendations for a cheapee source?
Thanks -
Re: Spindle Blanks
Re: Spindle Blanks
Mike Cunningham (Cape May)
>If you harvest and rough turn to spindle now and end seal, the stuff should be dry by late winter to turn for a spring show. Otherwise I'd go to my local mill and ask about rough 12/4 etc. You could also laminate.
Re: Spindle Blanks
Re: Spindle Blanks
Mike Brazeau
>David - I have been using up some of my log wood by making it into spindle blanks by sawing to size or roughing them to cylinders and waxing the ends with melted paraffin in an old electric frypan. Mark their weight and a date on them and you will be amazed how fast they dry down. I have them in the basement on shelves and sticker with some 3/4 x 3/4 sticker stock. Often one side of a log is not as good for a bowl as the other, so 1/2 to the bowl mill and the other half to spindle stock. A bandsaw is essential. I find a 3 TPI 1/2" blade seems to work best. I would say by spring you would have a good supply dried and ready to turn.
Mike
