Myland's Sanding Sealer
Ron McKinley
>What's the secret to using Myland's? Tried it today for the first time on a piece of redwood. Normally I use Watco on everything but thought I'd try the lacquer-based sealer and see if it would keep the redwood lighter than a Danish Oil.
What a mess! I've watched several Pros use it on their videos and it looked really simple. Just brush it on, wait a minute or two and buff it off with steelwool or fine sandpaper.
It left it really streaked and blotchy and had to use Watco on top of it to smooth it out. It was a fresh can that I just opened today. What am I missing? Thanks........Ron
Re: Myland's Sanding Sealer
Hooligan
>Don't really know. Never had that experience. The possibility that it was too thick an application, or it wasn't adequately dry before trying to cut it back exists.
If you can, post a picture or two.
Ron McKinley
>Too late. I've already "recovered" with Watco. Should have but didn't think about it.......Ron
Re: You didn't give it enough time to cure.
Jamie Donaldson
Ron McKinley
>How much time does it take to cure? I live in the dessert where it's really dry. Thought a minute to dry plus another rotating on the lathe would do it. In the Pro videos they don't give it any time before they start buffing it out. Or is that like Hollywood where they don't show all the time waiting for it to dry? .......Ron
Phil Joines Krum, TX
>Cut it 50% with laquar thinner. To apply stop the lathe, brush it on lightly, wipe the excess off with a paper towel, start the lathe and buff dry.
Dennis Daudelin
>I use it here on Cape Cod on turnings that have open grain. I apply it with the lathe stopped using a paper towel (VIVA-brand, less lint). After it's saturated, I turn on the lathe and run the paper towel back and forth like a friction polish. I let it dry for ~5 mins and then I'm ready for the next coat, which for me is normally friction polish.
I've not tried buffing it from there but think that it would have to dry (cure) for a longer period.
Dennis
>I'm not sure but I think part of the problem may be the redwood. The summer wood really soaks up the finish while the winter wood doesn't. You may have just needed more finish, or let that finish dry and apply a few more layers.
Ron McKinley
>From what everyone has said I think I may have been a little heavy-handed and brushed on too much. Also, Phil's suggestion to cut it 50% with thinner might solve the problem. The redwood was all heart with no sapwood and about 45 years old. Came from an old post from a horse corral. Thanks to all. I've got more pieces I can try it on. ....Ron
