oneway taper lock question
gary s clarke
>I have a spindle adaptor that is for the 2436 that goes from m33 to 1" 8thread so that I can use my vicmarc on the new lathe. Do I need to use a taper lock adaptor with the spindle adaptor? Also do I need a taper lock adaptor for a face plate? Oneway states that the taper lock adaptor is needed for their chucks to run true, so I have the adaptor for my stronghold chuck. thanks
Re: oneway taper lock question
Mike Brazeau
>Gary.
You do not need a taper lock adapter for the M33 to 1"x8TPI adapter, nor do you need one for the faceplate. I have the same adapter and use it for my Talon chuck to quickly move from one lathe to the other. I have noticed that on my lathe, you have to be carefull with the setscrew on the adapter. If you really cince it down it can cause the adpater to not run true. It is pretty easy to diagnose. Just watch the outer edge of the chuck and you can see any wobble created by tightening the screw too much. I assume you have the M33 taper for the Stronghold? Was not clear in your posting.
Mike
gary s clarke
>thanks Mike, you answered my question.
