Dougnut
Dougnut
Dougnut
Sean Troy
>Hello all, another question. Where might I find plans to make the dougnut jig for use in finishing off the bottoms of Hollow Forms? Thank you, Sean
Re: Dougnut
Re: Dougnut *LINK*
Art Liestman
>I wrote an article on how to make one which is archived on woodturningonline. You can search for "donut" on that page...
http://www.woodturningonline.com/Turning/Turning_a
Re: Dougnut
Re: Dougnut *LINK*
>Sean you can also go to the website below. I wrote an article on all sorts of reverse turning set ups and the Doughnut chuck was one of them. Go to the tips and techniques section.
http://www.cumberlandwoodturners.com
Re: Dougnut
Re: Dougnut
Sean Troy
>That's just what I was looking for. Thank you, Sean
Re: Dougnut
Re: Dougnut
Allen Neighbors
>Sean, here's a shot of my Doughnut Chuck. You can see enough of it to fashion one.
Re: Dougnut
Re: Dougnut Chuck front view
Allen Neighbors
>Decided to show the front side of it, too. :o)
Re: Dougnut
Re: Dougnut
Sean Troy
>This has got me itching to get one made. I want it for hollow forms. I use a vaccum chuck for bowls. thanks !
Re: Dougnut
Just a suggestion
Don Henthorn
>Although most plans don't show it I usually run a nut down each of the bolts in the doughnut and snug them up against the wood. I had a problem with a little bowl once and I tracked it down to the very slight movement the bolts could make in their holes which allowed the chisel to grab the bowl and scuff it up. Most bowls won't give this problem but having experienced it once I don't take chances any more.
Re: Dougnut
Re: Dougnut
Allen Neighbors
>This is the one I made for hollow forms.
Seven layers of 3/4 ply. Rounded, Coned inside, covered with pieces of mouse pad.
I use the same doughnuts to hold the hollowforms centered.
Re: Dougnut
Re: Dougnut
ben d.
>What is the marerial that you use to hold it all together.??
Re: Dougnut
Re: Just a suggestion
Sean Troy
>Good idea.
Re: Dougnut
Re: Kirsten Cone *LINK*
Pete Kekel - Kentucky
>Sean -
Under the heading 'More than one way to skin a cat . . .'
Look at the September newsletter from the Keystone Turners for an article written by Kim Blatt on the Kirsten Cone he uses for finishing his hollow forms. If you've ever seen his work (look at his album on WoW) then I'd have to say this idea works, too.
Keystone Woodturners
Re: Dougnut
Really like your "no-threaded-rod" approach
Craig Daymon
>I've got one half done that I had intended to use threaded rod. Now after seeing your woven approach, I'll rethink it.
Thanks Allen, looks much safer.
-Craig
Re: Dougnut
Re: Dougnut
Allen Neighbors
>3" rubber bands from WalMart office supply section. It will usually take about 4 or 5 bands on each of the 8 screws around the circumfrence. I cut slots in the doughnuts to accept the rubberbands. The screws are protruding about 3/8", and the sharp edges of the heads have been relieved by grinding the edge a little.
The rubberbands hold anything you can put on it.
Re: Dougnut
Re: donut design ??
Mike Hamilton
>Allen,
Is your outer ring larger in diameter than the base? Or did the picture just trick my eyes? I believe that lathe is a 1236 and it looks like you take full advantage of the max capacity.
I have a 1236 and this really appeals to me. Thanks.
Regards,
Mike Hamilton
Plainfield, IN
Re: Dougnut
Re: donut design ??
Allen Neighbors
>Yes, the outer rings are larger diameter than the chuck base. It's better to make sure that the rubber bands stay connected. :o)
I now use my Oneway lathe, and have turned a tenon on the back of the large wooden nut, so I can chuck it in my SN2. It still screws onto the spindle on Old Griz, too.
Re: Dougnut
Re: Really like your "no-threaded-rod" approach
Allen Neighbors
>Craig, this "no-threaded-rod" approach to the Doughnut Chuck is not original with me. If I remember correctly, I got this idea from Herm DeVries.
I also think the Kirsten Kone is a good idea, only I didn't know what it was called until I read Pete Kekel's post on this thread.
I made one a little different. I turned the cone from wood, with a tenon that chucks into my SN2, and covered it with Wal-Mart Foamies. I tapped a side hole with 1/4X20 threads to accept a set screw (1/4 X 20 bolt with knob on it)to lock the center rod in place. I use it on HFs that have a large enough opening for the padded end of the rod. On all the rest I use the Doughnut Chuck.
