THE WOODRAT IS BACK!
Newbie question
Newbie question
Newbie question
Gary B. in Central NY
>Although I'm a cabinetmaker, I'm a newbie to turning...My question is do I really need a Nova chuck or similar to turn a bowl?!? I have a faceplate, but I think I'm missing something....Thanks
Re: Newbie question
Having a chuck...
Blake Washburn
>... would REALLY help out in the finished product. I don't even think you can turn a bowl with just a faceplate. You really do need a chuck to turn a bowl.
Blake Washburn
Re: Newbie question
It can be done
stacey s
>You can turn a bowl with just a faceplate. Think about it scroll chucks have only been around for 20years? What did they use before then faceplates. You would just have to leave additional material at the base of the bowl to account for the depth of the screws into the wood for holding the bowl while hollowing and then when finishing the bottom you could just use the faceplace and a piece of wood attached to it for a jam chuck and finish the bottom of the bowl.
Stacey
Re: Newbie question
Re: Having a chuck...
Wally Dickerman in Arizona
>Whoa....The 4-jaw chuck appeared on the market around 1990..I have to say, we turned a lot of bowls before then. You do NOT need a chuck to turn a bowl. I have two chucks, a Oneway Stronghold and a Nova. I seldom use them. I prefer a glue block and screw chuck.
When I teach beginners classes we use glue blocks and faceplates. I do demonstrate how they are used. However, I want the students to know that while a chuck is a good tool to have and use, and in fact I recommend that they eventually get one, it isn't necessary.
Wally
Re: Newbie question
Re: Newbie question
Allen Neighbors
>Gary, you can turn a bowl with just a faceplate. Glue a waste block onto the bottom of the bowl blank. Screw the faceplate onto the wasteblock. Turn the bowl, and then part it off the waste block.
Round the waste block. Put a pad on it, and "jam" the inside of the bowl onto this, using the tailstock for pressure. Finish the bottom, leaving just a nub for the tailstock to hold it, and then just chisel off the nub and hand sand it. That's all there is to it.
Hope this helps.
Re: Newbie question
Excellent, thanks guys
>I figured there had to be a way around it, I want to turn a few bowls before I decide to plunk down that much money on a chuck.
Re: Newbie question
stacey s
>Oops. I was taking a guess as to how long the scroll chuck had been around. Back in 1990 I didn't even know what a lathe was, but I knew that it hadn't been around all that long. Stacey
Re: Newbie question
Brad Vietje
HORSEFEATHERS !!!
Brad Vietje
>Hey Blake,
People made bowls w/out chucks for, oh I dunno, maybe a few thousand years...?
Not to jump all over you or anything ;o), but while chucks make the job a little easier, and I think a little faster, but they don't make bowls POSSIBLE. A general term for bowl turning, and nearly all turning held at one end is "faceplate turning".
Any older book on turning that shows bowls at all (many are just spindles) will show how. A newer book that shows it very well is Woodturning: A Foundation Course, by the late Keith Rowley. The second edition came out about 2001, and has good color photos and everything. In fact, for a newbie turner, its a very good book to have. Another fave book of mine that shows quite a few variations on making bowls with a faceplate is Turning Green Wood, by Michael O'Donnell.
Since I'm in a feisty mood, I'll get up onto, no, make that WAY up on my high and mighty horse with a stellar proclamation from on high: Ready ? Here it is:
EVERY beginner that wants to learn to turn bowls should learn to do it without a chuck, and get pretty good at doing so, before adding a chuck to their tool arsenal. Here's why: in forcing yourself to figure out how to hold things on the lathe, you will start to tickle the problem-solving part of the brain, and if you play, safely, you might be amazed at all the oddball ways one can hold chunks of wood onto the lathe spindle. Keith Rowley shows one of my favorite ways to hold a turned foot to hollow out a small to medium bowl -- he taps it into a very slightly beveled recess turned in a block of scrap wood held on a -- you got it -- faceplate.
BTW, Blake, I've watched your posts recently, and you're off to a great start ! Keep up the good work.
Safe spinning,
Brad Vietje
On the road in Sturbridge, MA
Re: Newbie question
Brad Vietje
Feeling a little sheepish now...
Brad Vietje
>Now that I've read Wally's much more gentle, wise, and experienced reply, I'm feeling pretty bad for being so forceful, even though it was tounge in cheek...
I do hope Blake realizes that I was just having some fun, and I didn't mean to be a jerk -- REALLY !
Having fun while bored to near-death at a library conference,
Brad Vietje
usually from Newbury, VT
Re: Newbie question
Re: Newbie question
>Actually you can turn a bowl without even using a faceplate. I turn bowls between centers when roughing and have also done it in demos. You have a small cone on the bottom and on the inside that you have to carve away but it's pretty easy to do. When I rough turn bowls I often leave the same cone in the inside and bottom. This makes them very easy to remount on the lathe to true up the tenon so you can use a chuck or a faceplate.
Re: Newbie question
Ooooooooops!
Blake Washburn
>I apologize. I guess that shows how much I know! Oh well, I have a lot to learn yet. I guess I didn't think that through very well.
BW
Re: Newbie question
It's okay Brad...
Blake Washburn
>I've got "thick skin". I just took that as a learning experience. You just taught me somthing new.
Thanks
Blake Washburn
Re: Newbie question
Re: Newbie question *LINK*
Darrell Feltmate
>I have a great One Way chuck and almost never use it for bowls. Rough them between spur centers and finish turn them off a glue block. I think is is as fast and a little easier. Certainly it is cheaper. There are instructions on my web site. Look at the "bowls from log to salad" link.
Around the Woods
