ADVERTISE HERE - FREE TRIAL
Grizzly lathe owners, I have questions
Carol from AZ
>If you own a Grizzly lathe, the one's under a grand, what diameter is the tool post, and what diameter is the rod that tightens the banjo to the bed? Please include your model number.
Thanks.
Re: Grizzly lathe owners, I have questions
Jason Clark
>Carol, I have to G0462 16 X 43. The tool post is 25mm (which can be a problem, I had the mill the 1" post that came with my Kel Mcnaughton system down to 25mm). The banjo is secured via a multi-part system. http://images.grizzly.com/grizzlycom/manuals/g0462_m.pdf
part 61 - Eccentric rod is 5/8" diameter
part 65 - Bolt-A is I believe 18mm.
Stan Townsend
>I once owned a Grizzly lathe and just drilled the hole for the tool post out to 1" plus .010" . It will hold a 25 mm and accept a 1" very well .
Allen Neighbors
>Carol, I have a Grizzly Model G5979, 12" Swing, 36" Bed. The tool post is 25mm, which translates to near 15/16". The eccentric rod that clamps the banjo is about 5/8", and I don't know what that translates to in mms.
I broke the banjo, so I ordered two more. They came without the rods, and when I bought my new Oneway Lathe, I gave one to a man that built his own lathe. He made the banjo rod out of a long, 3/4" bolt, and just bored out the banjo holes to accept it.
Hope this gives you some ideas.
The eccentric rod is Part number P5979040 for the Grizzly Banjo.
The 19mm retaining ring for it is Number P5979041.
The "Special Screw" that goes on the eccentric rod is part number P5979023, and the M18-2.5 Hex nut for that Special Screw is P5979044A.
They all are inexpensive. Hope this helps a little.
