We value your privacy.
>When using the "T" style diamond wheel dressers on 1 inch wheels how do you insure that the face of the wheel remains 90 deg with the sides - or is this not important until it becomes obvious that the wheel face is now angled?
>It's really not a "jig" in the official sense of the word, I just took a piece of plywood about 4" long/wide with a notch cut out so the T dresser fits in snug. The bottom of the notch is only about 1/4" (guessing here) high and that rides on the rest. It works for me.
>I agree with Tony. I've completely used up 2 8" wheels and I've cleaned and trued them with the T shaped diamond hone by hand and just eyeballing the angle. The only thing it might change would be the angle of the wings but you'll actually change those more when your grinding if you don't be careful. If you look at your gouges closely you'll probaby see one wing is higher or longer or curved differently than the other. It really doesn't affect the use of the tool.
>I imagine the slight slope I might have is pretty insignificant compared to the number of times I have ground with a big groove somewhere down the center of the wheel. :)
>Could ya'll provide some input on what you use to dress your wheels I will be purchasing something new soon. I have the wolverine dressing jig and HATE!! it and I would like to replace it with a t-type dresser but would love some input on what others use
Re: suggestions for grinding wheel dressers *LINK*
Russ Babbitt Jr.
>I use the dresser from Craft Supply, a little more that 3 or 4 bucks, but I like it. I use it frequently to keep the wheels clean. I have and use the Wolverine dresser every few months to keep the wheels round and square. If you let the hand dresser bounce, too much pressure, you could get the wheels slightly out of round/balance. I like the combination of them both.
>Thanks Russ, the crafts supplies one is kinda what I had in mind. The $3.50 one from woodcraft is like the one that came with my delta grinder and it didn't last long at all so I will probably steer clear of that one although that is a great price. Thanks for the input
Vincent Welch
>Hi Stacy,
I seen where you wrote do not like the Wolverine Dressing Jig. I am courious as to what is it that you do not like about it. The reason why is because I really like mine! Mine cleans the wheel and smoothes out the surface so well when I sharpen it is as if I am placing my tool against a wheel that is not even spinning/rotating. The only draw back to the system is it is not fast.
>I use these kinds of tools to give the wheel a quick refreshing, but when I want to true up the wheel, I use the Oneway rig. It is totally different from the others in that it rides along its own tool rest -- at a fixed distance from the wheel -- , so it is always exactly parallel to the axis of the wheel. These others will simply follow whatever inaccuracy in axis alignment is already there.
>Like you said it is very slow and for me has always been a pain to get setup to use. After purchasing another type I might continue to use the wolverine for squaring but for quick cleaning I wantsomething that is more user friendly and quicker.
>It does take a minute to set up and use and there are time in which I with grab a diamond bar and give a quick pass or tweo over the grinding wheel but usually I will go for the OW jig. Thanks for the response. I figured that might have been the issue. Vince
