Have a question? Ask Woody!
Jet Outboard Tool Rest
Roger D. Coates
>I was at the Woodcraft store in Mobile, AL this morning for the Azalea Woodturners meeting and saw Jet has a new, stand alone, tool rest for outboard turning. It's three legged, cast iron, and seemed to weigh about 75lbs. Big footprint, but stable. The price was $349. Might be a viable option to the outboard attachment available for my DVR XP.
Roger in Ocean Springs, MS
Re: Jet Outboard Tool Rest
Ron McKinley
>I believe the outboard attachment for the DVR XP is about $50 cheaper.......Ron
Steven Antonucci
I did this for my Nova...
steve antonucci
>Blackpipe for the crossbar, filled with cement to dampen vibration, wooden plugs to keep it from pouring out.
I turned down the blackpipe in my chuck with a file and 50G sandpaper so it fit the banjo.
The stand on the left is a few two by pieces with a hole to support the end. Works way better than you'd probably guess.
Steve
Steve, that is what I did as a rest
Don Henthorn
>for my old Blount lathe. Turned a lot of fifteen inch dished stool seats with that rest.
I think it's way over priced!
Phil Joines Krum, TX
wilbur
>I thought the outboard attachment for the DVR XP attached directly to the lathe, so that there is a limit on how thick a piece it could be used for. Am I wrong on this?
Carole Valentine
>You are correct. It is basically only good for platters or very shallow bowls. Mine holds my chuck key, my spur and live centers, my calipers, my knockout bar and a few other sundries as well. In effect a very expensive tool rack.
