ADVERTISE HERE - FREE TRIAL
Al Crandall's hollowing rig
Carol from AZ
>I have spent some time this evening sorting out all the hollowing rig information and studying pictures.
Over on the Articles, Al wrote about his rig. I looked at the picture of his rig from the Indy gathering and found lots of closeups on the "other" forum. That has been very helpful. I have also looked at the commercial system and I will offer the information to Bill. It is his lathe and he will have to decide how much money he wants to spend getting it to work, and then getting it to work for him.
To continue the information gathering, I have some questions, and I hope my terminology will not be too confusing.
A round tool bar is inserted into the pipe nipple on the "D" handle of Al's rig. Does that mean the toolbar can rotate? If so, then it would have to rotate so the cutter meets the wood at the optimal angle. And then tightened at that rotation angle? Would a perpendicular handle bar welded to the toolbar be instrusive? Would it be better if it were clamped so it could slide and rotate on the tool bar?
Thanks all for helping out here. If this all works, I'm bringing my gouges back with me after Christmas. WooHoo!
Re: Al Crandall's hollowing rig
Al Crandall (NE of Indy)
>Hi Carol. Might as well get it from the horse�s mouth. The �round tool bar� on my design is a 5/8� x 10� long hex head bolt that has 2� of threads on it. All 2� of the threads are screwed into the �� black pipe after first tapping the inside of the pipe. To keep the hollowing torque from over-tightening the bolt, I drilled and tapped through both the pipe and the bolt for a �-20 grub screw. The bolt will not rotate under any circumstances. I have written a more comprehensive article with seven close up pictures of this rig, and could post it in seven messages here on the board if there is enough interest.
Carol from AZ
>Thanks, Al.
Sure hope there is sufficient interest!
I also noted you changed your plywood base. I compared the Article's picture (written 2 years ago) with the Indy gathering picture. Want to comment on that? Just more elegant or a need for more structural integrity? Any other changes that are not immediately apparent?
Dinyar Chavda
>Having missed the gathering, and not knowing where the pictures are of your rig, I would appreciate seeing the full description and pics. If you don't want to post it online, please email it to me.
TIA
D
Re: Need for vibration dampening.
>For vibration to occur, the amplitude of the wave is equal on both sides of the mean. If there is support on one side, the vibration will go away. When the trap rest is pivoted to the back, it has practically no support under it. In this position, a boring bar can be used to undercut a very wide shoulder on a hollow form. But the vibration was annoying, so I gusseted the top to eliminate the problem. If one gets a catch while hollowing, the end in the trap tries to lift so a top gussets were the answer. Please remember that the design goal of this rig was for it to be able to be constructed by any average woodworker with only a marginally equipped shop. It was never intended to be elegant, only functional.
Bruce
>interested
Jim Swank
>Interested
Me too, Al.
Norm Smith in Nova Scotia
elegance vs. functionality
Carol from AZ
>Frankly, kind sir, you have accomplished both!
Rick Bane
>I am very interested as well!!!!
Lan Brady
>Al,
And yet another interested soul here!!
I built my first one after a little play time in Georgia, but I want to build a heavier one this time. Copying your design, saved me countless errors.
Thanks, Lan
John Veerkamp
>interested. I am willing to pay for a snail mail copy since I have slow internet access.
John
Re: Post it if you will Al- would........
Jamie Donaldson
>... save us all some time not having to jump thru all the Freedom of Information Act hoops!
Dennis Fairman
>I'm interested Al. Thanks!
Dick Gerard bowlman
>I too am interested ... as you no doubt guessed by now!
Re: I will post the new article soon.
>All of my recent efforts have been toward geting a heat source back in my shop. I haven't forgotten you Dick.
Eddie Pacheco, San Jose, Ca.
>Hi Carol,
Hey, I was wondering, with your friend Bill having only the use of one arm, would it be more convienent to mount one of those inexpensive X-Y stages from Harbor Freight onto the lathe bed and then make a clamping fixture to secure the shank/shaft of a hollowing tool to the stage?
This will be sort of like the stage on a metal working lathe. This may work for shallow hollow forms and bowls.
Allen Neighbors
>Al, Allen is interested! :o)
Phil Joines Krum, TX
>That's an interesting idea. How about mounting a metal lathe boring bar to the top? One with a 1/2" shank.
