Bill's lathe
Bill's lathe
Bill's lathe
Carol from AZ
>My friend Bill's lathe is a Delta Homecraft. He sent me an email. I did a little web searching. One reference to it was "a Model A of a lathe"! So what does the collective wisdom here know about a Delta Homecraft? Next week I hope to get by his place and take some pictures, measure his arm/hand to answer one of your questions, and see what I can see about the tailstock. Anything special I should be looking at/for?
I sure hope we can this working, for him (and for me!).
Re: Bill's lathe
Look for Bill's lathe on this site: *LINK*
Jim
>Carol I'd take a look at the Old Woodworking Machinery website. They may have old owners manuals and parts manuals for that machine. There may also be some sales brochures on it. Those are always a hoot to peruse also. But more importantly, there will be information on the different configurations and what it's supposed to look like.
Old Woodworking Machines
Re: Bill's lathe
Re: Bill's lathe
Mike Brazeau
>Carol - my first lathe was a Rockwell Homecraft and I still have it. I am saving for my eldest grandson. Very solid cast iron and simple with 5 1/2" swing and about 35 or 36" spindle length capacity. Has No. 2 morse taper and 1 x 8 TPI headstock. I think mine dates to the late 50's. I paid $150 for it with Delta carbon steel tool set in 1969 or 1970. Has a great stand with cast iron legs and pine 2x10 planks the lathe bed and motor is mounted on. I have a 5 page manual with parts list. It is 1.8 Mb pdf file I can email to you.
Mike
Re: Bill's lathe
Re: Bill's lathe
Keith Newton
>I have one sitting back in the netherlands of my shop also. I have offered to give it to a young couple, along with a little band saw, but they haven't come after it.
This is a pretty light duty lathe, Unless it was mounted on a very heavy / sturdy stand, it probably should only be considered for spindle turning, or very small bowls. but hey, I guess we all need to start somewhere.
Re: Bill's lathe
Found this pic on-line
gil jones
>Don't know if it is the one your friend has, but the name was the same.
Looks like it would be a fine starting lathe.
Gil
Re: Bill's lathe
Re: Bill's lathe
Stan Townsend
>It will take about 30 inches between the Hollowform and the tail stock for the elbotool to work well without a bed extension. any diameter will be OK. Stan Townsend
Re: Bill's lathe
Re: Bill's lathe
Jennifer@Indy.USA
>Oh, Carol I hope you can find a working lathe too. All study and no turning might make make Carol a cranky crafter! I know you are really missing doing things with your hands and just making things. So I hope this works out for you.
Good Luck!!
Jen :)
Re: Bill's lathe
Re: Look for Bill's lathe on this site:
Carol from AZ
>I already did, Jim. Thanks. When I get a chance to look at it next week, at least there is a chance I'll recognize it. :)
Re: Bill's lathe
Re: Bill's lathe
Carol from AZ
>How very cool, Mike. I'll let you know. Thanks.
Re: Bill's lathe
Re: Bill's lathe
Carol from AZ
>He will let me use it, Jen. We just have to get it working. Then we'll get a rig for him to use it as well. He is the guy with the use of only one arm.
He is very generous to allow me to do this. I just wanted to reciprocate in some way for him.
Re: Bill's lathe
Brad Vietje
Re: Bill's lathe *LINK*
Brad Vietje
>These are pretty decent lathes in my view.
My dad bought one brand spankin' new about 1957, which he used until his death 2 years ago. It has an 11" swing, and a gap that allows a 14" swing for plates and platters. This can also be a real annoyance when trying to position the rest for smaller items, as that gap can limit where you can put the toolrest banjo -- not all models have the gap bed. Good heavy cast iron, step pulleys, and pretty decent bearings. The nice thing about these is you can go out and replace headstock the bearings rather easily for about $ 50.00 if they're shot. My dad got the benchtop model, but there are also some with heavy legs and the motor mounted below. the stock banjo onm my dad's was a little flexy, so it was replaced with a beefier one.
Here's my humble opinion: this lathe (my dad's old one at least) is a better lathe than a Jet 1236, so it isn't a toy or a learner's model. The 1236 is easier to use, with its not-really-all-that-great Reeves-style drive system, but by and large, the quality and tollerances were better 40 years ago than they are now, so the machine is a real workhorse. I've worked my 1997 1236 into 2 new sets of pully sheaves, re-machined the toolrest banjo, and replaced the entire (badly designed) tailstock casting, belts, handles and other annoyances, so it just isn't as beefy as the old Delta Homecraft.
Again, just one fella's view, but it should make quite a nice lathe. For pics and ideas for modification, look at Bill Tarleton's site, where he shows riser blocks and a bench-mount toolrest for bigger pieces. He has now moved up to a Powermatic, but there's good Delta lathe info still.
Safe spinning,
Brad Vietje
Newbury, VT
Bill's Wood Creations
Re: Bill's lathe
Brad Vietje
Good Powermatic Index Wheel Ideas, too
Brad Vietje
