We value your privacy.
>Jamie, this is a box I have posted previously in other places. I finally have built a photo set up and have retaken some pictures of some of my boxes. I would appreciate you and others with photographic expertise taking a look at this picture and giving me advice on how to better photograph my work.
For those interested, this is a box in Masur birch and is 2 3/4" in diameter and 4 3/4" tall.
>.....that reduces the appearance of depth that properly placed shadows impart. I can't tell how many light sources you are using, and the light diffusion in this set-up is allowing too much bounce and too much illumination on the background, not the usual problems! I recommend trying a single light source on one side/front, then moving the shadow on the opposite side to best advantage.It might also help to move the background farther back if possible- can't tell much else without seeing the actual set-up you are using.
>...I didn't say anything about this nice box! The lighting technique is called "high key" and is frequently used for portraits, especially for subjects with long noses. The flat lighting without shadows, and with a telephoto lens, compresses or flattens the appearance of the subject, be it a box or a prominant schnoz!
>.. worked with lighting on TV studio sets, I would assume that a good lighting technician could be either friend or foe to an anchor person with a prominant probiscus!
>.... that my "Phrugal Photo Studio" tutorial will be posted here on WC soon, but in the meantime it is posted under the tips menu on my web site JamieDonaldsonWoodturner.com and I would encourage you to check it out.
>..... that the dark woods have been manipulated with halos and other tricks in Photoshop to make them visable against the black background. That also creates a critical exposure problem that many amateur photographers are not prepared to handle when they don't have spot metering equipment.
>the black background, but look at the artist listings. Amazing how many WCer's and WOWies there are listed. We should be proud and grateful for all the talent gathered here.
>Thank Jamie and all who helped. I will see if I can try some of the things you suggested. My set up has a single source of light and is dependent on reflective sidewalls for the equal lighting. I will have to make some adjustments. I had the box pretty far back in the setup when I took the photo so moving it forward and away from the background may help. I could have made the piece more prominent in the photo I posted, I just didn't crop it because I was seeking advice on lighting and shadows. Normally I do make the piece more prominent in the photo. Thanks again for all the help and now I will see if I can make the adjustments.
>Mike there's a simple solution. Just put something less reflective on one wall and move it further from the background. I often use a piece of black construction paper. You can fold it so it sits up and move it closer or further from the subject to see how it darkens one side. You can also move it in an arc so the dark area falls where you want on the piece.
You might even try a little piece of aluminum foil wrapped around cardboard to produce a slight specular highlight somewhere near the top. This will help it "pop" a little more. Sometimes that gives a little more roundness to the piece. This won't work well with super glossy pieces unless your really careful. I use white cards, black cards and silver cards to give shape to polished silver subjects. Usually on wood I use either the silver cards or small mirrors (I happen to have about a 100 of those)
>John, I do so appreciate your suggestions. I was wondering what I could do to effect the changes Jamie suggested short of re-building my photo booth and you did it for me for a few cents....I would never have thought of just using some construction paper. I assume I could use blacks, grays etc and the foil wrapped as you suggested and acheive widely different looking photos of the same piece. Thanks so much for helping me understand the photo process better. Thanks to all...
>That was a head slapper when I thought of it. I'll have to post photos of an even better idea that is even more of a headslapper. It's very difficult to describe on paper but a photo is worth a 1000 words.
Another technique I use frequently is wire screen. If you are using diffusion panels like the photo booths, sometimes your light appears as a hotspot on the piece. This is usually due to the panels being to transparent or the light being too close to the panels. I put several small pieces of wire screen between the light source and reflection. Often you can just lay them on the panel or tape them to the panel. You have to place get back at the camera and look at the reflection and then figure out exactly where to place them so they reduce the intensity of the reflection. It takes about 3 layers to make a very noticeable difference. I've been able to take a refection down from being an abnoxious hotspot to being just a light spot that actually shows the grain of the wood.
