Protect your Shop against Water Heater Leaks *LINK*
Andy DiPietro
Andy DiPietro
>Here is a good safety valve to protect your shop or house against Hot Water Heater leaks. I have a full basement woodworking/woodturning shop. I was concerned that my hot water heater was old and would rupture when I was at work. So I installed a new water heater with a drip pan and a WAGS valve. The WAGS (Water and Gas shutoff Valve) is cheap insurance to protect your house and/or shop. Check out the link. I paid $150.00 at a plumbing supply house. The valve sits in the drip pan with the inlet cold water piped thru it. If the heater leaks and fills the pan the valve will close and shut off the water. There is a jumper wire from the valve to the gas thermostat that opens up when the valve opens. Hence it shuts off the gas too. Check out the website for a better explanation.
http://www.wagsvalve.com/
Re: Protect your Shop against Water Heater Leaks *LINK*
Juergen
>What happens to the 60-80 gallons of water in the tank? I would think a drain or sump neary would complete the setup.
I had an 80 gallon tank go on me in a 2d floor condo. There was a 3/4" tall pan under the tank with small hole for a nearby drain. The shutoff would have helped but the pan was to shallow to contain the water and needless to say flooded both my unit and the one below.
>You raise interesting questions. In many cases if you shut off the water supply/pressure, the leak will stop or nearly stop. The advantage would be that you limit the damage to the amount of water in the tank, but 50 to 80 gallons can do a lot of damage. OTOH, not nearly as much as an unlimited amount from a pressure leak.
We really take a sort of half @$$ approach to this. The building code now requires pans under water heaters and upstairs clothes washers, but they are only about 2" deep and many have a 3/4" "drain". Its like "you can make me do this, but you can't make me do it well".
This device would work well if there pan were about three inches deep and the drain were about an inch up from the bottom and maybe an inch and a half in diameter. Then the device would shut off the supply when the water got an inch deep and the drain would carry off the rest of it.
Many of the washer pans I see are mashed and broken by installing the washer.
Remember that the pans do little or no good if you get a spraying leak and the water misses the pan.
Also, things like solenoids and valves and pumps are unlikely to be reliable if they sit there waiting for five or ten years and then are called into play.
There are devices you can get that monitor the whole house water flow. You set it to lets say fifty gallons. If you draw less, it just resets and waits. If you hit fifty gallons, it cuts off the water until you manually reset it. That way, if the leaks occurs while you are out, you only suffer the damage from the first fifty. Also great for limiting those long showers teenagers like.
Also remember that all water heaters eventually leak. Some condos and apartment complexes schedule the replacement and just replace all of them at ten years or whatever.
Bob Fawcett
>I have a tankless heater. They cost a little more to start with, but the energy consumption is far less than a tanked heater. I use propane and I can run my house a whole year on a single tank (250). The propane runs the hot water, cook top, and gas logs. I also used the hot water to fill the new pool at the beginning of spring. As long as there is fuel, you never run out of hot water.
If you got a leak, it would be limited to the water in the pipes with a shutoff like yours.
