Poseidon's platter
Poseidon's platter
Poseidon's platter
Leppikallio
>This is latest piece I just completed. Birch and instant rust & verdigris.
Unfortunately I can't show effect so well I would like but I think the warm natural wood goes so well with rust and verdigris. "Bare" wood is buffed, partially colored and then waxed.
This is 9" diameter, about 3" high.
What do you think? Yes/No/Burn it soonish?
Re: Poseidon's platter
RevDoug
>I like what you've done here. The illusion of a well made piece of china that has a metal rim is great. Did you have any crack lines in the "discolored" areas of the "china" portion? If not, a very fine line created with a pen of some sort. This piece shows some real imagination. You deffinately need to keep it and for sure put a price tag on it that is worthy of a fine piece. Excellent work.
Turn 'em round,
Very nice.
Craig Daymon
>I like what you've done. The only thing I think I might have tried with it is to mimic a crackle glaze on the inside, with just the crackle lines (somehow) and natural wood between. Very similar to what you have done here. I don't know how to create those very fine lines in a way up to the rest of what you have done here. I suspect burning with even a very fine skew blade might not be quite right.
But that's just personally. I think these look great. Very nice work.
-Craig
Steven Antonucci
Like the idea...
steve antonucci
>but this piece is too much like a bowl to be a platter. I think you should be substantially larger diameter if it's going to be 3" deep, or shallower if it's going to be 9" wide.
I absolutely love the overall effect, just not crazy about the proportions.
Steve
Re: Like the idea...
don lewonczyk
>Decoy carvers use technical pens to paint in the very fine lines in each feather, don't know if the proper word is vermisillon, anyway I can't spell to good either but they use Kohnoor pens made in Germany. They come in alarge assortment of tips and you can get all different colors. They don't run, the ink stays put and you barely touch the surface you are writing on. The tips are interchangeable with the body so you can have 10 tips and one body if you go that way. Drafting suppy or art supply stores have them but they aren't cheap but with that beautiful piece you completed you can afford them. Very creative and post more of your work please. Don
don lewonczyk
>OOps, I forgot to mention, the tips are refillable, just have to clean them good in between uses and color changes. Don L
