General 260 speed control
Bill Crommett
>Last month I got a tremendous catch turning some dry maple which shut down the lathe. Inspection showed no lights or LEDs as was the previous experiences following a stall.
My communication with the factory led to the suggestion that I purchase a new Altivar speed control to the tune of $ 1175.00.
Has anyone out there got a more resonable alternative or a source of repair for such an accessory, or do I have to convert this lathe to a dirct drive-three pulley arrangement ?
Re: General 260 speed control
Bill, I have a controller
T Daniel
>I bought my controller from the guy who used to sell Generals here, Woody Goforth. I think it may be the same one. Mine is for 3 hp. I no longer need it.
TD
Re: General 260 speed control *LINK*
Doug Leite
>Bill, Is your machine 220 v input and 1 hp? If so the item at this link might work.
If your machine is different specs, look around in the big book pafe to find what you need.
Aloha
http://www1.mscdirect.com/CGI/NNSRIT?PMCTLG=00&PMA
Re: Bill, I have a controller
Bill Crommett
>TD: I thionk mine is a 2 Hp, but I will look closely and see what it says. By the way, would a 3 Hp unit work on a 2 HP motor ?
Thanks for the respons -- both to you and to Doug .
Keith Tompkins
Keith Tompkins
>Bill, before you panic, did you check your power supply? Check your breakers or fuses.....remember, there are two legs on a 220 circuit...one side may still be operational. The control will not function @ 120 V.
Worst case, the controller can be sent to the company for servicing. Under some conditions, the speed control may need to be reset, according to the manual. I cannot imagine a few catches causing that much damage to your speed control....a thorough diagnosis is in order before you order anything. The speed control is a complex device, including a thermistor and four relays. A competent electrician should be able to give a good idea of the problem.
Converting the lathe to manual speed controls is not the answer, as the 2 hp motor is 3 phase.
Bob Fawcett
>Bill,
Most speed controllers operate by varying the frequency of the 3phase output to change the speed of the motor. A unit for a 3hp motor would have a higher current output capacity than one for a 2hp. If the frequency range is the same, it should work on a 2hp. Terry's controller may well work on your lathe even if they are different hp.
You might also see if the original manufacturer is willing to help.
You should be able to find enough information on both the motor plate and the controller plate to find a suitable replacement.
The link below may be able to supply one if you ultimately must purchase a new one.
Speed controllers
Bill Crommett
>I checked on the motor plate (which was not an easy job, because the motor plate was backwards on top of the motor, back in the cabinet) and found that it is a 1750 speed 1 Hp moter. I had forgotten that the motor would be a three phase application, but will double check the 220 volt oputput again. The factory did not seem to be interested in repairs, only in selling a replacement.
Thanks for all the good replies. I am now going to have to find a knowledgable electronic electrician to repair my unit. Any suggestions ?
Bob Fawcett
>There aren't too many electronic shops left that actually repair. Most of them are just parts changers. The manufacturer of your unit may have a repair depot. If not you might try looking for a hobbyist. I have built audio equipment and there are websites similar to WC for audio stuff. I don't know of any that deal with power electronics.
Most of the speed controls we use are called inverter drives. They actually take the AC supplied turn it into DC, then make 3 phase AC out of the DC with the ability to vary the AC frequency. My unit has a frequency range of 1 - 400 hertz. My motor is 1725 rpm like yours, so I suspect yours has a similar frequency range.
It just occured to me that an electric motor shop may be able to help.
Bob Fawcett
>This might work on your lathe
VFD drive
Yes, if it's a VFD
Phil Joines Krum, TX
>You can use a lower rated motor but if you use a larger most controllers will limit the motor to the VFD's (inverter's) size.
Is it really 1HP, not 2HP?
Bill Howatt
Re: Is it really 1HP, not 2HP?
Bill Crommett
>I thought all along that the motor was a 2 Hp, but the plate on the motor lists the Hp as 1 Hp.
