Kerosene stove problem
Carole Valentine
>I just had my stove drained, dried and a new wick installed and filled my jug with fresh kero. Stove worked fine last night. Today something is not right...it smokes when it is first lit and the flame is very low and erratic even though the wick is turned all the way up. Could there be water in the kero I just bought? If so, is there anyway to get rid of it? I hate to throw away a 5 gal. jug of kero (and don't know where to throw it anyway!) I used the additive (basically a scented alcohol I think) in it as I always have before. Will water permanently contaminate the new wick or will it eventually straighten itself out? Any advice?
Re: Kerosene stove problem
Jennifer@Indy.USA
>Carole, I wish I had an answer for you....I'm getting ready to fire mine up today for the first time this season. Mine was new last year. keeping my chilly fingers crossed....for both of us!
Jen
Lan Brady
>Carole,
I had a simlar problem several years ago. I put in a new wick, filled with kero, and lit the fire. Worked fine, but a few days later it began to smoke as well. The guy at the hardware store said I should have let the kero soak in the new wick for 2 hours before lighting. It had burned the top off. I adjusted the wick and it works fine still.
May not be your problem but worth a shot!
Good Luck, Lan
ben d.
>As another reply said the wick burned off and is now too short. You should be able to pull it up and start over and work fine. Had the same thing happen also. Hope it works for you also.
Carole Valentine
>Ben and Lan, the wick soaked up kero overnight before I lit it so I don't think that was the problem. The wick looks to be a normal height (at least what I am used to.) I just went out and fired it up again and though it was real slow coming up and smoked some, it did finally straighten itself out a bit for about half an hour. Then the flame started getting smaller again. At one point, part of the wick was flame-less! That's why I was wondering about water and if that was the case, is the wick ruined if it gets "watered"? If there is water in my storage tank, can the fuel be saved?
Sean Troy
>Hey all, can you tell me about the type of heater you have. i need to get something to keep me warm in the shop.I'm not used to the cold comming from Arizona to Kentucky. What about ventilation with a kerosene heater? What about dust in the air? thanks, Sean
Barbara Gill, Remlik VA
>Sean, I put in a ventless propane heater winter before last and have been very happy with it. I have the smallest wall mounted unit they made as I only heat a small area. When propane burns you get carbon dioxide and water. All of the non-vented units automatically shut off if the oxygen level goes down. With my shop that certainly would not be a problem. Tight it is not. :-)
>Sean I've been using a kerosene heater for years. No problems with Dust or ventilation other than the smell which doesn't bother me but drives some people crazy. I've had huge amounts of dust floating around and even built up on the thing with no problems. I do clean it off regularly and make it a rule to never get anything closer than 2 feet from it. I think they say 3 but 2 has been fine so far.
>I had the same problem when I changed mine and I don't think I did anything other than just keep using it. It started working fine after a day or so.
Carole Valentine
>Thanks, John. Will keep buring it and see if if it starts to do OK. Seems to be doing alright this afternoon, but it's time to refill, so we'll see.
Sean, I have been using one of the big round ones for 4 years. No problems at all with dust or ventilation (my shop is anything BUT tight!) I have no ceiling or insulation so basically most of the heat goes out the ridge vent. LOL However, with a fan, it keeps the shop fairly comfortable except in the coldest weather. I also have no dust collection whatsoever except a box fan with furnace filters when I am sanding. BTW, this type of dust control was ranked right up there with the best in a recent mag article! LOL
Me, too, Sean. Thanks for Asking.
Ruth Niles
>There's a nice new looking karosene heater in my garage and I've been thinking "why not use it" but have always heard spooky stories about them. You all live just a tab bit further south than me but I don't think our winters are that much colder. Are they?
Re: Me, too, Sean. Thanks for Asking.
Sean Troy
>We've dipped into the high 20's the last few nights. Tonight is going to be a tad warmer because of the rain and clouds. I'd rather see it snow than be cold and rainy. I'm going to have to fix up some sort of heating system.
Ruth Niles
>One of the local guys up here suggested the suspended hot air furnace with either oil or propane. I want something with a thermostat, I keep my shop at least 44 degrees at all times and turn it up when I'm working in it.
Randy Privett
>Carol,
Everytime I had a new wick put in a heater, I would burn it in for the first tank. Then I would turn the wick up and using the edge of a pocket knife or whatever, scrape the top of the wick knocking the burnt edge off of it. A new wick seems to burn all the fuzzy stuff into a solid on the top. You then can re-light it and this should get it burning right again. Check it out, won't hurt.
Brad Vietje
Brad Vietje
>If you regularly clean the carbon gunk off the top of the wick with a fine brass brush (brush upward with the wick in place), it will light and burn better.
Safe heating,
Brad Vietje
Newbury, VT (with very fine snow flurries outside...)
