Veritas - Innovation in Tools
Cedar Oil on cedar wood
Brad Bittle
>Turned a nice natural edged cedar turning...decided wanted to retain the cedar aroma and soaked with cedar oil instead of danish. Couple days later, a white fungus or mold started appearing all over the vessel, including the turned and natural bark areas. Wiped the substance off daily for a few days. Decided to coat out with danish oil at this point, but the mold continues to appear after daily wipings. What to do? Thought of using mold remover like Tilex, but their instructions say do not use on wood. Please, what to do?
Thanks,
Brad in Knoxville
Re: Cedar Oil on cedar wood
Carole Valentine
>Cedar will do that sometimes if it is not completely dry when you put a finish on it. I am not sure it is mold though. I think it may be something to do with the oils/resins in the wood. It will eventually stop. The good news is the white powder is easily buffed off.
Hooligan
>Yeah, what Carole said. The oil seems to have a solvent quality on green turned pieces, causing resins to bleed.
Brad Bittle
>Thanks for the answers, guys.
Ralph Watts
>Brad,
If you can get all of the gunk off, give it a coat of shelac. It will stop the bleeding, not add or detract from the color much, and can be overcoated with almost anything.
