Alcohol Drying vs Pentacryl vs Turners' Choice
Dick Gerard bowlman
>Has anyone used Pentacryl or Turner's Choice from CedarCide.com? What are the pluses and minuses?
Also, a while back I read a post from someone that included a link to eBay for a large container to hold DNA for soaking. I think it was something like 17 gal. capacity, had a nice tight fitting lid, was made of plastic and came from a RV supplier? Oh and it was round (nice shape, huh?
What do others use to store DNA for soaking items larger than say, 12 inches in diameter?
Thanks in advance ...
Re: Alcohol Drying vs Pentacryl vs Turners' Choice
Steven Antonucci
I used to use pentacryl
steve antonucci
>but I stopped because the stuff never seems to dry. And it stunk. An alcohol worked better for way less money.
As far as big items go, I usually double bag them in garbage bags and place the bags in a storage bin. Then I pour the DNA into the bag and prop it into place so that the object is covered. I've DNA soaked 18" bowls this way. When you are done, just cut a small drain hole in the bottom of the bags (over your bucket, of course) and Voila!
Steve
Tony Reynolds somewhere near Newark, Ohio
>I use a 33 gallon Rubbermaid trashcan with lid. It will hold a 18" bowl. The lid fits OK, but I think alcohol vapors are heavier than air so I haven't had a problem with fumes as they tend to stay in the can with the lid on. I maybe wrong in this assumption but I don't smell alcohol when I walk in the shop.
Tony
Re: I used to use pentacryl
Ed Karch
>I do the same as Steve with the garbage bags using a galvanized wash tub for the really big stuff.
Re: Alcohol is the only 1 of the 3 I've used, but
Al Crandall (NE of Indy)
>The message you referenced might have been mine. I have several 17 gal plastic drums which I bought on ebay. They were shipping containers for small lots of pelletized plastic for molding operations. Came to me very clean and the lid seals very tight. She said that several people have used them for gear stowage while canoeing because they are watertight. They taper from 18-20 diameter and are 13" deep. Do an eBay search for plastic barrel. I have no idea if she still sells them.
Ric Taylor
Ric Taylor
>I found a container at Big Lots for about $10. It is a picnic cooler with a Coca Cola label on the side, about 20" tall and about 14" in diameter, cylinder shaped. It appears to be made out of a plastic similar to PVC and has a tight-fitting lid that is designed to be a seat so that you can sit on the cooler. It came with a styrofoam liner that I tossed. I don't notice any fumes and there doesn't seem to be any evaporation.
Ric
Dick Hines
Dick Hines
>I use the DNA process. I store it in a big hamper I got at one of the Box stores. I tried the soap stuff for a while but find that DNA works faster for me.
