Made a tool handle last night. (borders on long)
Joe in a Cleveland suburb
>Hi.
I don't wonder over here often as I never (very rarely) use my little Jet lathe. But last night I needed to make a little tool handle so I gave it a shot - I've used my lathe maybe 3 or 4 times in the last couple years. So, I am a lathe noob basically.
Here's the scenario - I needed to make a chisel for cleaning out sockets of hand-cut dovetails. So I went to Home Depot and bought a cheapo Buck Brothers chisel. Ground the chisel into the shape of a DT and cut the plastic handle off then measured the shaft thingy. I measured it to be 5/16" using my trusty Handy Man of America screw measuring device (some freebies are worth the price I guess - still won't join though!). I then drilled (using a drill press) a 5/16" hole into the center of a piece of scrap 1" square Walnut. I screwed a 5/16" lag bolt (with its head cut off) into the hole and mounted that to the drill chuck thingy on my lathe. I didn't really need to "screw" the lag bolt in since it was the same size as the hole.
Turned the little handle and all came out fine. I thing tried to mount the new handle onto the chisel and my pretty walnut handle split. I didn't really have to pound it all that hard. I expected some resistance. In fact, I drilled a test hole into some scrap poplar and the chisel shaft fit in the hole. It was a tight fit but not that tight.
Should I have heated the chisels shaft up or something? Does that somehow help? What's the trick?
Btw, I know walnut may not be the best wood for a chisel handle but this will be used for paring not chopping. Maybe I should use a piece of Cherry or Ash?
Thanks,
Joe
Re: Made a tool handle last night. (borders on long)
Ed Karch
>A trick the old timers us is to heat the tang red hot then shove in the handle. It sort of melts the wood in to the shape of the tang.
>Joe It sounds like either your hole was undersized or possibly the chisel tang was oversize, possibly metric. Heating it as Ed said will work well. Was the tang round. If so just drill a hole slightly larger, possibly 3/8 and then epoxy it in the hole. You will have to drill a very small hole through the side near the bottom to give some air and hydraulic relief. When you push the tang in the handle the air/hydraulic pressure will push it right back out. The little hole lets the air and some epoxy seem out so you can get the tang in. The epoxy of course fills up the little hole.
If the tang is tapered like many file tangs are then heating it red hot is the simplest method. Drill a hole the same size as the small end of the tang and then heat about the first 1/2" or so of the tang to red hot and drive the handle on.
If your worried about overheating the chisel just clamp a pair of vice grips near the end of the tang and these will absorb any extra heat and keep it away from the good part of the chisel.
>Thanks guys. I wondered about the heat thing. I will give it a go.
If heat doesn't do the trick, I'll go the epoxy route. Heck, I have enough scrap laying around that I should get it right sooner or later!
Thank you.
Joe
Bob Fawcett
>Most chisel handles for tang tools also have a metal ferule around the end of the wooden handle. Its purpose is to add strength so the wood is less likely to split. I have made these from a short length of copper or brass pipe and sometimes other plumbing fittings.
